Handling Fluorescence in a Uni-directional Spectral Path Tracer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2018
We present two separate improvements to the handling of fluorescence effects in modern uni-directional spectral rendering systems. The first is the formulation of a new distance tracking scheme for fluorescent volume materials which exhibit a pronounced wavelength asymmetry. Such volumetric materials are an important and not uncommon corner case of wavelength-shifting media behaviour, and have not been addressed so far in rendering literature. The second one is that we introduce an extension of Hero wavelength sampling which can handle fluorescence events, both on surfaces, and in volumes. Both improvements are useful by themselves, and can be used separately: when used together, they enable the robust inclusion of arbitrary fluorescence effects in modern uni-directional spectral MIS path tracers. Our extension of Hero wavelength sampling is generally useful, while our proposed technique for distance tracking in strongly asymmetric media is admittedly not very efficient. However, it makes the most of a rather difficult situation, and at least allows the inclusion of such media in uni-directional path tracers, albeit at comparatively high cost. Which is still an improvement since up to now, their inclusion was not really possible at all, due to the inability of conventional tracking schemes to generate sampling points in such volume materials.
fluo_sampling.pdf (28.96 Mo) Télécharger le fichier
presentation_egsr_fluo_sampling.key (33.38 Mo) Télécharger le fichier
presentation_egsr_fluo_sampling.pdf (14.06 Mo) Télécharger le fichier
Format : Figure, Image
hal-01818826 , version 1 (19-06-2018)
Michal Mojzík, Alban Fichet, Alexander Wilkie. Handling Fluorescence in a Uni-directional Spectral Path Tracer. Computer Graphics Forum, 2018, 37 (4), pp.77 - 94. ⟨10.1111/cgf.13477⟩. ⟨hal-01818826⟩
808 Consultations
486 Téléchargements
