An inverse obstacle problem for the wave equation in a finite time domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems and Imaging Année : 2019
We consider an inverse obstacle problem for the acoustic transient wave equation. More precisely, we wish to reconstruct an obstacle characterized by a Dirichlet boundary condition from lateral Cauchy data given on a subpart of the boundary of the domain and over a finite interval of time. We first give a proof of uniqueness for that problem and then propose an " exterior approach " based on a mixed formulation of quasi-reversibility and a level set method in order to actually solve the problem. Some 2D numerical experiments are provided to show that our approach is effective.
article_hal.pdf (1.74 Mo) Télécharger le fichier
hal-01818956 , version 1 (19-06-2018)
Laurent Bourgeois, Dmitry Ponomarev, Jérémi Dardé. An inverse obstacle problem for the wave equation in a finite time domain. Inverse Problems and Imaging , 2019, 19 (2), pp.377-400. ⟨10.3934/ipi.2019019⟩. ⟨hal-01818956⟩
578 Consultations
159 Téléchargements
