Multiple security domain model of a vehicle in an automated platoon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This chapter focuses on the security of automated vehicle platoons. Specifically, it examines the vulnerabilities that occur via disruptions of the information flows among the different types of sensors, the communications network and the control unit in each vehicle of a platoon. Multiple security domain nondeducibility is employed to determine whether or not the system can detect attacks. The information flows among the various domains provide insights into the vulnerabilities that exist in the system and whether the model is nondeducible. If nondeducibility is found to be true, then an attacker can create an undetectable attack. Defeating nondeducibility requires additional information sources, including invariants pertaining to vehicle platoon operation. A platoon is examined from the control unit perspective to determine if the vulnerabilities are associated with preventing situational awareness, which could lead to vehicle crashes.
460140_1_En_5_Chapter.pdf (1.17 Mo) Télécharger le fichier
hal-01819138 , version 1 (20-06-2018)
Paternité
Uday Kanteti, Bruce Mcmillin. Multiple security domain model of a vehicle in an automated platoon. 11th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2017, Arlington, VA, United States. pp.81-97, ⟨10.1007/978-3-319-70395-4_5⟩. ⟨hal-01819138⟩
233 Consultations
65 Téléchargements
