Exploiting web ontologies for automated critical infrastructure data retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Semantic web technologies play a significant role in many open data initiatives, including geo-mapping projects and platforms. At the same time, semantic principles are also promoted as a key enabling factor for multi-domain analyses of critical infrastructures as well as for improved emergency response. This chapter reviews the recent literature on ontology-based analysis and management of critical infrastructures, and proposes the use of ontology processing techniques to bridge the gap between infrastructure knowledge representation and available (often general-purpose) open data sources. In particular, it discusses an approach for matching a given critical infrastructure ontology to an ontology built on OpenStreetMap (OSM) tags that enables structured access to the associated geographical dataset.
460140_1_En_7_Chapter.pdf (1.02 Mo) Télécharger le fichier
hal-01819139 , version 1 (20-06-2018)
Paternité
Luca Galbusera, Georgios Giannopoulos. Exploiting web ontologies for automated critical infrastructure data retrieval. 11th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2017, Arlington, VA, United States. pp.119-136, ⟨10.1007/978-3-319-70395-4_7⟩. ⟨hal-01819139⟩
43 Consultations
136 Téléchargements
