Demo: Unleashing the power of LED-to-camera communications for IoT devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Adrien Desportes
  • Fonction : Auteur
  • PersonId : 987239
In this demonstration, we propose a line of sight LED-to-camera communication system based on an ordinary LED and a smartphone. We designed a cheap temperature sensor prototype as a proof of concept of a near communication framework for the Internet of Things. To illustrate a typical use case, we have programmed the micro-controller to broadcast the ambient temperature value through the LED. The user, with his smartphone and our Android application can then retrieve the transmitted information, aiming the board with the camera.
vlcs16-demo-abstract-duque.pdf (2.91 Mo) Télécharger le fichier
hal-01819404 , version 1 (20-06-2018)
Alexis Duque, Razvan Stanica, Hervé Rivano, Adrien Desportes. Demo: Unleashing the power of LED-to-camera communications for IoT devices. Proceedings of the 3rd Workshop on Visible Light Communication Systems, Oct 2016, New York City, United States. ⟨10.1145/2981548.3003712⟩. ⟨hal-01819404⟩
186 Consultations
116 Téléchargements
