Using Convolutional Neural Network with Asymmetrical Kernels to Predict Speed of Elevated Highway - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Di Zang
  • Fonction : Auteur
  • PersonId : 1033367
Jiawei Ling
  • Fonction : Auteur
Jiujun Cheng
  • Fonction : Auteur
Keshuang Tang
  • Fonction : Auteur
Xin Li
  • Fonction : Auteur
  • PersonId : 758835
  • IdRef : 193139367
In this paper, we present a deep learning based approach to performing the whole-day prediction of the traffic speed for the elevated highway. In order to learn the temporal features of traffic speed data in a hierarchical way, an improved convolutional neural network (CNN) with asymmetric kernels is proposed. Speed data are collected from loop detectors of Yan’an elevated highway of Shanghai. To test the performance of the presented method, we compare it with some conventional approaches of traffic speed estimation. Experimental results demonstrate that our method outperforms all of them.
978-3-319-68121-4_22_Chapter.pdf (689.21 Ko) Télécharger le fichier
hal-01820901 , version 1 (22-06-2018)
Paternité
Di Zang, Jiawei Ling, Jiujun Cheng, Keshuang Tang, Xin Li. Using Convolutional Neural Network with Asymmetrical Kernels to Predict Speed of Elevated Highway. 2nd International Conference on Intelligence Science (ICIS), Oct 2017, Shanghai, China. pp.212-221, ⟨10.1007/978-3-319-68121-4_22⟩. ⟨hal-01820901⟩
61 Consultations
441 Téléchargements
