Ensemble Learning Using Multi-Objective Evolutionary Algorithms, Journal of Mathematical Modelling and Algorithms, vol.29, issue.2, pp.417-445, 2006. ,
DOI : 10.1109/4235.687878
Multiobjective Neural Network Ensembles Based on Regularized Negative Correlation Learning, IEEE Transactions on Knowledge and Data Engineering, vol.22, issue.12, pp.1738-1751, 2010. ,
DOI : 10.1109/TKDE.2010.26
URL : http://staff.ustc.edu.cn/%7Ehchen/papers/TKDE2010.pdf
Software effort estimation as a multi-objective learning problem Article No, ACM Trans. Softw. Eng. Methodol, vol.22, issue.4 35, p.32, 2013. ,
DOI : 10.1145/2522920.2522928
URL : http://www.cs.bham.ac.uk/~minkull/publications/MinkuYaoTOSEM12.pdf
A multi-objective ensemble method for online class imbalance learning, 2014 International Joint Conference on Neural Networks (IJCNN), pp.3311-3318, 2014. ,
DOI : 10.1109/IJCNN.2014.6889545
Convex Hull-Based Multiobjective Genetic Programming for Maximizing Receiver Operating Characteristic Performance, IEEE Transactions on Evolutionary Computation, vol.19, issue.2, pp.188-200, 2015. ,
DOI : 10.1109/TEVC.2014.2305671
Reusing Genetic Programming for Ensemble Selection in Classification of Unbalanced Data, IEEE Transactions on Evolutionary Computation, vol.18, issue.6, pp.893-908, 2014. ,
DOI : 10.1109/TEVC.2013.2293393
URL : http://www.cs.bham.ac.uk/~xin/papers/urvesh_final_tec13.pdf
, , p.234
Yaodong Cui, and Zuqiang Meng Weighting Features Before Applying Machine Learning Methods to Pulsar Search, p.241 ,
Qian Yin, and Hongfeng Wang Machine Perception Patch Image Based LSMR Method for Moving Point Target Detection, p.251 ,
Zhijing Xu, and Xiangyang Xue An Improved Image Transformation Network for Neural Style Transfer, p.260 ,
, 268 Xin Zhang and Zhiying Yang A Coding Efficiency Improvement Algorithm for Future Video Coding . . . . . 279
Step Pedestrian Detection Algorithm Based on RGB-D Data, p.288 ,
Yimin Chen, and Lizhuang Ma Inferring and Analysis Drivers Violation Behavior Through Trajectory, p.295 ,
, , p.305
311 Shuangyan Shan and Zhijing Xu Intelligent Information Processing Channels' Matching Algorithm for Mixture Models 321 Chenguang Lu Understanding: How to Resolve Ambiguity 333 Shunpeng Zou and Xiaohui Zou Exploration on Causal Law of Understanding and Fusion Linking of Natural Language, 344 Peihong Huang Contents XXVII Depression Tendency Recognition Model Based on College Student's ,
, , p.351
Applications Traffic Parameters Prediction Using a Three-Channel Convolutional Neural Network, p.363 ,
Keshuang Tang, and Xin Li Research of the Evaluation Index System of Green Port Based on Analysis Approach of Attribute Coordinate, 372 Xueyan Duan, Xiaolin Xu, and Jiali Feng Two Stages Empty Containers Repositioning of Asia, p.379 ,
and Xiaofeng Wang Speed Optimization of UAV Vehicle Tracking Algorithm, p.390 ,
Application of Ant Colony Optimization in Cloud Computing Load Balancing ,
, 409 Jianguo Huang, Lang Sun, and Hu Meng Designing an Optimal Water Quality Monitoring Network . . . . . . . . . . . . . . 417
426 Haitao Qi and Zhijing Xu A Composite Weight Based Access Network Selection Algorithm in Marine, p.435 ,
, , p.445
