Motion Vector Coding in the HEVC Standard, IEEE Journal of Selected Topics in Signal Processing, vol.7, issue.6, pp.957-968, 2013. ,
DOI : 10.1109/JSTSP.2013.2271975
Motion vector coding techniques for HEVC, 2011 IEEE 13th International Workshop on Multimedia Signal Processing, pp.1-6, 2011. ,
DOI : 10.1109/MMSP.2011.6093817
Description of Core Experiment 9 (CE9): MV Coding and Skip/Merge operations, Document of Joint Collaborative Team on Video Coding, p.609, 2011. ,
Motion vector coding algorithm based on adaptive template matching, 2010 IEEE International Workshop on Multimedia Signal Processing, pp.222-227, 2010. ,
DOI : 10.1109/MMSP.2010.5662023
Enhanced AMVP mechanism based adaptive motion search range decision algorithm for fast HEVC coding, 2014 IEEE International Conference on Image Processing (ICIP), pp.3696-3699, 2014. ,
DOI : 10.1109/ICIP.2014.7025750
Parametric motion vector prediction for hybrid video coding, 2012 Picture Coding Symposium, pp.381-384, 2012. ,
DOI : 10.1109/PCS.2012.6213369
Motion modeling for motion vector coding in HEVC, 2015 Picture Coding Symposium (PCS), pp.154-158, 2015. ,
DOI : 10.1109/PCS.2015.7170066
Robust Rotational Motion Estimation for efficient HEVC compression of 2D and 3D navigation video sequences, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.1379-1383, 2013. ,
DOI : 10.1109/ICASSP.2013.6637877
Efficient Prediction Motion Vector Candidate Selection Algorithm for HEVC, ITC-CSCC :International Technical Conference on Circuits Systems, Computers and Communications, pp.402-403 ,
Motion vector search window prediction in memory-constrained systems, Applications of Digital Image Processing XXXII, pp.74430-74430, 2009. ,
DOI : 10.1117/12.829404
Adaptive search range selection in motion estimation, 2010 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.918-921, 2010. ,
DOI : 10.1109/ICASSP.2010.5495282
Adaptive Motion Search Range Prediction for Video Encoding, IEEE Transactions on Circuits and Systems for Video Technology, pp.1903-1908, 2010. ,
DOI : 10.1109/TCSVT.2010.2087551
Adaptive search range algorithm based on Cauchy distribution, 2012 Visual Communications and Image Processing, pp.1-5, 2012. ,
DOI : 10.1109/VCIP.2012.6410741
Adaptive direction search algorithms based on motion correlation for block motion estimation, IEEE Transactions on Consumer Electronics, vol.57, issue.3, pp.1354-1361, 2011. ,
DOI : 10.1109/TCE.2011.6018894
Adaptive search range motion estimation using neighboring motion vector differences, IEEE Transactions on Consumer Electronics, vol.57, issue.2, pp.726-730, 2011. ,
DOI : 10.1109/TCE.2011.5955214
Fast motion estimation with adaptive search range adjustment, Optical Engineering, vol.9, issue.4, pp.40504-040504, 2007. ,
DOI : 10.1109/83.350809
URL : https://www.spiedigitallibrary.org/journals/Optical-Engineering/volume-46/issue-4/040504/Fast-motion-estimation-with-adaptive-search-range-adjustment/10.1117/1.2721767.pdf
Dynamic Control of Motion Estimation Search Parameters for Low Complex H. 264/AVC Video Coding, 2006 Digest of Technical Papers International Conference on Consumer Electronics, pp.481-482, 2006. ,
DOI : 10.1109/ICCE.2006.1598520
Common test conditions and software reference configurations, 2013. ,
Calculation of average PSNR differences between RD-curves, p.33, 2001. ,
