Abstract : With the coming of low-carbon era the concept of green port becomes more and more important due to the occurrence of abnormal global environmental change. Founded on the previous literatures, the Analysis Approach of Attribute Coordinate is used to analyze evaluation of green port. An index system including three attributes and ten factors is put forwarded. The quantification methods of different indicators are also proposed according to the different property and scoring methods of indicators. The green port evaluation index system can be used to evaluate the port’s green operation performance. It is also a good instrument to construct a green port operation for decision makers of port organizations.
https://hal.inria.fr/hal-01820932 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, June 22, 2018 - 10:44:20 AM Last modification on : Monday, June 24, 2019 - 2:12:03 PM Long-term archiving on: : Monday, September 24, 2018 - 8:38:38 PM
Jiali Feng, Xueyan Duan, Xiaolin Xu. Research of the Evaluation Index System of Green Port Based on Analysis Approach of Attribute Coordinate. 2nd International Conference on Intelligence Science (ICIS), Oct 2017, Shanghai, China. pp.372-378, ⟨10.1007/978-3-319-68121-4_40⟩. ⟨hal-01820932⟩
