Orienting of attention, Quarterly Journal of Experimental Psychology, vol.197, issue.1, pp.3-25, 1980. ,
DOI : 10.1126/science.408924
Symbolic Control of Visual Attention, Psychological Science, vol.12, issue.5, pp.360-365, 2001. ,
DOI : 10.1037/0096-1523.16.1.121
URL : http://dare.ubvu.vu.nl/bitstream/1871/17439/2/Hommel%20Psychological%20Science%2012%285%29%202001%20u.pdf
Gaze cueing of attention: Visual attention, social cognition, and individual differences., Psychological Bulletin, vol.133, issue.4, pp.694-724, 2007. ,
DOI : 10.1037/0033-2909.133.4.694
URL : http://europepmc.org/articles/pmc1950440?pdf=render
Sequence effects in a spatial cueing task: Endogenous orienting is sensitive to orienting in the preceding trial, Psychological Research, vol.14, issue.5, pp.516-523, 2007. ,
DOI : 10.1037/0096-3445.109.2.160
Vá zquez-Marrufo, M.: Sequential P3 effects in a Posner's spatial cueing paradigm: trial-by-trial learning of the predictive value of the cue, Acta Neurobiol. Exp, vol.69, pp.155-167, 2009. ,
The effect of previous trial type on inhibition of return, Psychological Research, vol.50, issue.4, pp.411-417, 2007. ,
DOI : 10.1080/14640748508400920
Sequence effects by non-predictive arrow cues, Psychological Research, vol.29, issue.2, pp.253-262, 2012. ,
DOI : 10.1037/0096-1523.29.2.483
URL : https://link.springer.com/content/pdf/10.1007%2Fs00426-011-0339-2.pdf
Gaze cueing as a function of perceived gaze direction, Japanese Psychological Research, vol.10, issue.3, pp.264-272, 2013. ,
DOI : 10.1016/j.tics.2006.08.006
URL : http://onlinelibrary.wiley.com/doi/10.1111/jpr.12001/pdf
Priming of popout: III. A short-term implicit memory system beneficial for rapid target selection, Visual Cognition, vol.74, issue.11, pp.571-595, 2000. ,
DOI : 10.1007/978-1-4899-5379-7
Rapid learning in attention shifts: A review, Visual Cognition, vol.32, issue.3, pp.324-362, 2006. ,
DOI : 10.1016/S0959-4388(03)00033-3
