Discrete Cuckoo Search with Local Search for Max-cut Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yingying Xu
  • Fonction : Auteur
  • PersonId : 1033432
Zhihua Cui
  • Fonction : Auteur
  • PersonId : 1033433
Lifang Wang
  • Fonction : Auteur
  • PersonId : 1033434
Max-cut problem is a well-known NP-hard problem, in this paper, a hybrid meta-heuristic algorithm is designed to solve it. In this algorithm, the discrete cuckoo search is employed to find the approximate satisfied solution, while the local optimal solution is used to further improve the performance. To test the validity, three other algorithms are used to compare, simulation results show our modification is effective.
978-3-319-68121-4_7_Chapter.pdf (235.92 Ko) Télécharger le fichier
hal-01820945 , version 1 (22-06-2018)
Paternité
Yingying Xu, Zhihua Cui, Lifang Wang. Discrete Cuckoo Search with Local Search for Max-cut Problem. 2nd International Conference on Intelligence Science (ICIS), Oct 2017, Shanghai, China. pp.66-74, ⟨10.1007/978-3-319-68121-4_7⟩. ⟨hal-01820945⟩
58 Consultations
71 Téléchargements
