I. Goodfellow, . Bengio, and A. Courville, Deep Learning, Practical Machine Learning Tools and Techniques, 2016.
H. Kaneko and K. Funatsu, Adaptive soft sensor based on online support vector regression and Bayesian ensemble learning for various states in chemical plants, Chemometrics and Intelligent Laboratory Systems, vol.137, pp.57-66, 2014.
DOI : 10.1016/j.chemolab.2014.06.008
URL : https://manuscript.elsevier.com/S0169743914001294/pdf/S0169743914001294.pdf
Z. Ge, Z. Song, and P. Wang, Probabilistic combination of local independent component regression model for multimode quality prediction in chemical processes, Chemical Engineering Research and Design, vol.92, issue.3, pp.509-521, 2014.
DOI : 10.1016/j.cherd.2013.09.010
X. Yuan, Z. Ge, and Z. Song, Locally Weighted Kernel Principal Component Regression Model for Soft Sensing of Nonlinear Time-Variant Processes, Industrial & Engineering Chemistry Research, vol.53, issue.35, pp.13736-13749, 2014.
DOI : 10.1021/ie4041252
M. Ghaedi, M. R. Rahimi, A. M. Ghaedi, I. Tyagi, S. Agarwal et al., Application of least squares support vector regression and linear multiple regression for modeling removal of methyl orange onto tin oxide nanoparticles loaded on activated carbon and activated carbon prepared from Pistacia atlantica wood, Journal of Colloid and Interface Science, vol.461, pp.425-434, 2016.
DOI : 10.1016/j.jcis.2015.09.024
K. Were, D. T. Bui, Ø. B. Dick, and B. R. Singh, A comparative assessment of support vector regression, artificial neural networks, and random forests for predicting and mapping soil organic carbon stocks across an Afromontane landscape, Ecological Indicators, vol.52, pp.394-403, 2015.
DOI : 10.1016/j.ecolind.2014.12.028
D. R. Baughman and Y. A. Liu, Neural Networks in Bioprocessing and Chemical Engineering, 1992.
J. L. Mcdonagh, D. S. Palmer, T. Van-mourik, and J. B. Mitchell, Are the Sublimation Thermodynamics of Organic Molecules Predictable?, Journal of Chemical Information and Modeling, vol.56, issue.11, pp.2162-2179, 2016.
DOI : 10.1021/acs.jcim.6b00033
A. Tabernero, E. M. Martín-del-valle, and M. A. Galán, On the use of semiempirical models of (solid+supercritical fluid) systems to determine solid sublimation properties, The Journal of Chemical Thermodynamics, vol.43, issue.5, pp.711-718, 2011.
DOI : 10.1016/j.jct.2010.12.011
F. Leon and S. Curteanu, Performance comparison of different regression methods for a polymerization process with adaptive sampling, International Journal of Computer, Electrical , Automation, Control and Information Engineering, vol.10, issue.10, pp.1515-1519, 2016.
M. Pirdashti, K. Movagharnejad, P. Mobalegholeslam, S. Curteanu, and F. Leon, Phase equilibrium and physical properties of aqueous mixtures of poly (vinyl pyrrolidone) with trisodium citrate, obtained experimentally and by simulation, Journal of Molecular Liquids, vol.223, pp.903-920, 2016.
DOI : 10.1016/j.molliq.2016.07.118
R. M. Hlihor, M. Diaconu, F. Leon, S. Curteanu, T. Tavares et al., Experimental analysis and mathematical prediction of Cd(II) removal by biosorption using support vector machines and genetic algorithms, New Biotechnology, vol.32, issue.3, pp.358-368, 2015.
DOI : 10.1016/j.nbt.2014.08.003
R. Chelariu, G. D. Suditu, D. Mareci, G. Bolat, N. Cimpoesu et al., Prediction of Corrosion Resistance of Some Dental Metallic Materials with an Adaptive Regression Model, JOM, vol.61, issue.4, pp.767-774, 2015.
DOI : 10.1002/maco.200905527
S. Curteanu, M. Smarandoiu, D. Horoba, and F. Leon, Naphthalene sublimation. Experiment and optimisation based on neuro-evolutionary methodology, Journal of Industrial and Engineering Chemistry, vol.20, issue.4, pp.1608-1611, 2014.
DOI : 10.1016/j.jiec.2013.08.007
URL : https://hal.archives-ouvertes.fr/hal-01821058
M. Hall, E. Frank, G. Holmes, B. Pfahringer, P. Reutemann et al., The WEKA data mining software, ACM SIGKDD Explorations Newsletter, vol.11, issue.1, pp.10-18, 2009.
DOI : 10.1145/1656274.1656278
D. E. Rumelhart, G. E. Hinton, and R. J. Williams, Learning internal representations by error propagation, Parallel Distributed Processing: Explorations in the Microstructure of Cognition 1, 1986.
A. J. Smola and B. Schölkopf, A tutorial on support vector regression, Statistics and Computing, vol.14, issue.3, pp.199-222, 2004.
DOI : 10.1023/B:STCO.0000035301.49549.88
J. G. Cleary and L. E. Trigg, K*: An Instance-based Learner Using an Entropic Distance Measure, 12th International Conference on Machine Learning, pp.108-114, 1995.
DOI : 10.1016/B978-1-55860-377-6.50022-0
S. Painuli, M. Elangovan, and V. Sugumaran, Tool condition monitoring using K-star algorithm, Expert Systems with Applications, vol.41, issue.6, pp.2638-2643, 2014.
DOI : 10.1016/j.eswa.2013.11.005
L. Breiman, Random Forests, Machine Learning, vol.45, issue.1, pp.5-32, 2001.
DOI : 10.1023/A:1010933404324
F. Leon and S. Curteanu, Evolutionary Algorithm for Large Margin Nearest Neighbour Regression, 7th International Conference on Computational Collective Intelligence Technologies and Applications, pp.286-296, 2015.
DOI : 10.1145/1390156.1390302
F. Leon and S. Curteanu, Large margin nearest neighbour regression using different optimization techniques, Journal of Intelligent & Fuzzy Systems, vol.10, issue.4, pp.1321-1332, 2017.
K. Q. Weinberger and L. K. Saul, Distance metric learning for large margin nearest neighbor classification, Journal of Machine Learning Research, vol.10, pp.207-244, 2009.
