Iliou Machine Learning Data Preprocessing Method for Stress Level Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Theodoros Iliou
  • Fonction : Auteur
  • PersonId : 1033525
Georgia Konstantopoulou
  • Fonction : Auteur
  • PersonId : 1033526
Konstantinos Anastasopoulos
  • Fonction : Auteur
  • PersonId : 1033527
Dimitrios Lymberopoulos
  • Fonction : Auteur
  • PersonId : 1008213
George Anastassopoulos
  • Fonction : Auteur
  • PersonId : 992515
Data pre-processing is an important step in the data mining process. Data preparation and filtering steps can take considerable amount of processing time. Data pre-processing includes cleaning, normalization, transformation, feature extraction and selection. In this paper, Iliou and PCA data preprocessing methods evaluated in a data set of 103 students, aged 18–25, who were experiencing anxiety problems. The performance of Iliou and PCA data preprocessing methods was evaluated using the 10-fold cross validation method assessing seven classification algorithms, IB1, J48, Random Forest, MLP, SMO, JRip and FURIA, respectively. The classification results indicate that Iliou data preprocessing algorithm consistently and substantially outperforms PCA data preprocessing method, achieving 98.6% against 92.2% classification performance, respectively.
467708_1_En_30_Chapter.pdf (1.04 Mo) Télécharger le fichier
hal-01821068 , version 1 (22-06-2018)
Paternité
Theodoros Iliou, Georgia Konstantopoulou, Ioannis Stephanakis, Konstantinos Anastasopoulos, Dimitrios Lymberopoulos, et al.. Iliou Machine Learning Data Preprocessing Method for Stress Level Prediction. 14th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2018, Rhodes, Greece. pp.351-361, ⟨10.1007/978-3-319-92007-8_30⟩. ⟨hal-01821068⟩
165 Consultations
178 Téléchargements
