Generalized pursuit learning schemes: new families of continuous and discretized learning automata, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.32, issue.6, pp.738-749, 2002. ,
DOI : 10.1109/TSMCB.2002.1049608
URL : http://ce.sharif.edu/courses/84-85/2/ce717/resources/root/ao02.pdf
Approximate counts and quantiles over sliding windows, Proceedings of the twenty-third ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '04, pp.286-296, 2004. ,
DOI : 10.1145/1055558.1055598
Tracking Quantiles of Network Data Streams with Dynamic Operations, 2010 Proceedings IEEE INFOCOM, pp.1-5, 2010. ,
DOI : 10.1109/INFCOM.2010.5462241
URL : http://www.bell-labs.com/user/erranlli/publications/quantINFOCOM-mini10.pdf
Monitoring networked applications with incremental quantile estimation, Statistical Science, pp.463-475, 2006. ,
DOI : 10.1214/088342306000000583
URL : http://doi.org/10.1214/088342306000000583
Incremental quantile estimation for massive tracking, Proceedings of the sixth ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '00, pp.516-522, 2000. ,
DOI : 10.1145/347090.347195
URL : http://www.stttelkom.ac.id/staf/MAB/CS4943/ref/anomaly detection - outlier-fraud/fraud detection/Bell labs signature Fraud mgmt system/Incremental Quantile Estimation for Massive Tracking.pdf
An improved data stream summary: the count-min sketch and its applications, Journal of Algorithms, vol.55, issue.1, pp.58-75, 2005. ,
DOI : 10.1016/j.jalgor.2003.12.001
URL : http://dimacs.rutgers.edu/~graham/pubs/papers/cm-latin.pdf
Space-efficient online computation of quantile summaries, ACM SIGMOD Record, vol.30, issue.2, pp.58-66, 2001. ,
DOI : 10.1145/376284.375670
A General CPL-AdS Methodology for Fixing Dynamic Parameters in Dual Environments, IEEE Transactions on Systems, Man, and Cybernetics, Part B (Cybernetics), vol.42, issue.5, pp.1489-1500, 2012. ,
DOI : 10.1109/TSMCB.2012.2192475
, IEEE Transactions on Systems, Man, and Cybernetics, issue.6, pp.221473-1483, 1992.
Frugal Streaming for Estimating Quantiles, Space-Efficient Data Structures, Streams, and Algorithms, pp.77-96, 2013. ,
DOI : 10.1016/0304-3975(80)90061-4
Selection and sorting with limited storage, Theoretical Computer Science, vol.12, issue.3, pp.315-323, 1980. ,
URL : http://wrap.warwick.ac.uk/46321/1/WRAP_Munro_cs-rr-024.pdf
Continuous and discretized pursuit learning schemes: various algorithms and their comparison, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.31, issue.3, pp.31277-287, 2001. ,
DOI : 10.1109/3477.931507
URL : http://www.scs.carleton.ca/~oommen/papers/PurAlgCn.PDF
Absorbing and ergodic discretized two-action learning automata, IEEE Transactions on Systems, Man, and Cybernetics, issue.16, pp.282-293, 1986. ,
Stochastic searching on the line and its applications to parameter learning in nonlinear optimization, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.27, issue.4, pp.733-739, 1997. ,
DOI : 10.1109/3477.604122
URL : http://www.scs.carleton.ca/~oommen/papers/PrLrnNew.PDF
The asymptotic optimality of discretized linear reward-inaction learning automata, IEEE Transactions on Systems, Man, and Cybernetics, vol.14, issue.3, p.14, 1986. ,
DOI : 10.1109/TSMC.1984.6313256
Discretized pursuit learning automata, IEEE Transactions on Systems, Man, and Cybernetics, vol.20, issue.4, pp.931-938, 1990. ,
DOI : 10.1109/21.105092
Automata learning and intelligent tertiary searching for stochastic point location, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.28, issue.6, pp.947-954, 1998. ,
DOI : 10.1109/3477.735407
Parameter learning from stochastic teachers and stochastic compulsive liars, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.36, issue.4, pp.820-836, 2006. ,
DOI : 10.1109/TSMCB.2005.863379
Discretized reward-inaction learning automata, Journal of Cybernetics and Information Science, pp.24-29, 1979. ,
A Space-Efficient Recursive Procedure for Estimating a Quantile of an Unknown Distribution, SIAM Journal on Scientific and Statistical Computing, vol.4, issue.4, pp.706-711, 1983. ,
DOI : 10.1137/0904048
Space-efficient on-line selection algorithms, Computer Science and Statistics: Proceedings of the Eleventh Annual Symposium on the Interface, pp.308-311, 1978. ,
A Novel Strategy for Solving the Stochastic Point Location Problem Using a Hierarchical Searching Scheme, IEEE Transactions on Cybernetics, vol.44, issue.11, pp.2202-2220, 2014. ,
DOI : 10.1109/TCYB.2014.2303712
A Stochastic Search on the Line-Based Solution to Discretized Estimation, Advanced Research in Applied Artificial Intelligence, pp.764-773, 2012. ,
DOI : 10.1007/978-3-642-31087-4_77
URL : https://brage.bibsys.no/xmlui/bitstream/11250/137963/1/Yazidi_2012_Stochastic.pdf
Dicsretized qunatile estimation using the spl theory Unabridged journal version of this paper, 2018. ,
Multiplicative Update Methods for Incremental Quantile Estimation, IEEE Transactions on Cybernetics, issue.99, pp.1-10, 2017. ,
DOI : 10.1109/TCYB.2017.2779140
A Higher-Fidelity Frugal Quantile Estimator, International Conference on Advanced Data Mining and Applications, pp.76-86, 2017. ,
DOI : 10.1016/j.patcog.2016.05.001
