A Survey on Heuristic-Based Routing Methods in Vehicular Ad-Hoc Network: Technical Challenges and Future Trends, IEEE Sensors Journal, vol.16, issue.17, 2016. ,
DOI : 10.1109/JSEN.2016.2583382
Akram: CACONET: Ant Colony Optimization (ACO) Based Clustering Algorithm for VANET, 2016. 3. EG. Talbi: A Taxonomy of Hybrid Metaheuristics, 2002. ,
DOI : 10.1371/journal.pone.0154080
URL : http://doi.org/10.1371/journal.pone.0154080
A Multi-Head Clustering Algorithm in Vehicular Ad Hoc Networks, International Journal of Computer Theory, Engineering, 2013. ,
Agarwal: An information propagation scheme for VANETs. IEEE Intelligent Transportation Systems Conf, pp.155-160, 2005. ,
DOI : 10.1109/itsc.2005.1520039
URL : http://140.138.176.194/meeting/2009/v2v/07-09/An_information_propagation_scheme_for_VANETs.pdf
Little: A mobility based metric for clustering in mobile ad hoc networks, Int. Conf. Distributed Computing Systems Workshop, pp.413-418, 2001. ,
Sreenath: An Efficient Clustering Algorithm for Vanet, International Journal of Applied Engineering Research, vol.12, 2000. ,
Cuckoo search via Le´vy flights, IEEE Proceedings of world congress on nature & biologically Inspire Computing, pp.210-214, 2009. ,
DOI : 10.1109/nabic.2009.5393690
, VANET Clustering Based Routing Protocol Suitable for Deserts. Sensors journal, 2016.
Clustering in vehicular ad hoc networks using affinity propagation. Ad Hoc Network journal, 2014. ,
DOI : 10.1016/j.adhoc.2013.10.005
Valaee: Mobility-based clustering in VANETs using affinity propagation Sainz: Cluster based MAC in VANETs for safety applications, The 28th IEEE Conference on Global Telecommunications International Conference on Advances in Computing, Communications, Informatics (ICACCI) 13. A. B. M. Moniruzzaman, Md. S. Rahmann: Analysis of Topology Based Routing Protocols for Vehicular Ad-Hoc Network (VANET). International Journal of Computer Applications, pp.1424-1429, 2009. ,
A Weighted k-Medoids Clustering algorithm for effective stability in Vehicular Ad Hoc Networks A scatter search heuristic for the capacitated clustering problem Scatter search for project scheduling with resource availability cost: A scatter search heuristic for the capacitated clustering problem, 19th International Conference on Communication Systems, Applications Laguna, R. Marti: Fundamentals of scatter search and path relinking. Control and Cybernetics Journal, pp.533-547, 2000. ,
Scatter Search: Methodology, Implementations, 2003. ,
DOI : 10.1007/978-1-4615-0337-8_11
URL : https://link.springer.com/content/pdf/10.1007%2F978-1-4615-0337-8_11.pdf
The Network Simulator -https, Tabu Search. Annals of Operations Research, vol.21, 1993. ,
Multipath routing in mobile Ad-hoc network using meta-heuristic approach, 2017 International Conference on Advances in Computing, Communications and Informatics (ICACCI), 2017. ,
DOI : 10.1109/ICACCI.2017.8126036
