Use Cases for 5G Networks Using Small Cells
In this paper, we discuss the main use cases and scenarios we consider in the context of 5G ESSENCE project [1]. The first use case investigates edge network acceleration at a stadium. The second use case is focused on end-to-end slicing for mission critical applications. The third scenario considers in-flight communications and entertainment system.
