, 5G-PINE On Edge Cloud Architecture and Joint Physical Virtual Resource Orchestration for, p.27
, , p.39
Miguel Catalan Cid, Hicham Khalife, and Fidel Liberal Enhancing Network Management via NFV, MEC, Cloud Computing and Cognitive Features: The " 5G ESSENCE " Modern Architectural Approach, p.50 ,
Ioannis Giannoulakis, Michail-Alexandros Kourtis, Emmanouil Kafetzakis, Eirini Vasilaki, Marinos Agapiou, and Mike Iosifidis e-Health Services in the Context of IoT: The Case of the VICINITY Project, p.62 ,
, Are 5G Networks and the Neutral Host Model the Solution to the Shrinking, p.70
Carlos Colman-Meixner, and Dimitra Simeonidou An Experimental Assessment of Channel Selection in Cognitive Radio Networks, p.78 ,
Time Traffic Fluctuations in a Cellular Network: Measurements' Analysis and Potential, p.89 ,
Detecting Question Intention Using a K-Nearest Neighbor Based Approach, p.101 ,
El-Den, and Mihaela Cocea Incremental Learning for Large Scale Classification Systems, p.112 ,
Mohamed Bader-El-Den, and Athanasios Tsakalidis Argumentative Discourse Concepts as Revealed by Traversing a Graph, p.123 ,
Nikos Karacapilidis, and Vassilis Tampakas Query Disambiguation Based on Clustering Techniques 133 Panagiota Kotoula and Christos Makris Automatic Selection of Parallel Data for Machine Translation ,
, 157 Georgios Drakopoulos, Dimitrios Tsolis, Antonia Stefani, and Phivos Mylonas How Much Different Are Two Words with Different Shortest Periods . . . . . . 168
Non-coding RNA Sequences Identification and Classification Using a Multi-class and Multi-label Ensemble Technique 179 Michalis Stavridis ,
, , p.189
Kotouza, Fotis E. Psomopoulos, and Pericles A. Mitkas XXVI Contents Towards String Sanitization ,
Costas Iliopoulos, and Grigorios Loukides Efficient Recognition of Abelian Palindromic Factors and Associated Results, 211 Costas S. Iliopoulos and Steven Watts HEALTHIOT Recommender Systems for IoT Enabled m-Health Applications . . . . . . . . . . 227 ,
Home IoT Infrastructure for the Support of Independent Living of Older Adults Votis, and Dimitrios Tzovaras A Generic Approach for Capturing Reliability in Medical Cyber-Physical Systems, p.250 ,
and Dimosthenis Kyriazis Advancing Quantified-Self Applications Utilizing Visual Data Analytics and the Internet of Things ,
