Actors: a model of concurrent computation in distributed systems, 1986. ,
Multi-Threaded Actors, Proceedings 9th Interaction and Concurrency Experience, pp.8-9, 2016. ,
DOI : 10.1109/SCCC.2007.4
URL : http://arxiv.org/pdf/1608.03322
, Programming, Composing, Deploying for the Grid, pp.205-229, 2006.
Parallel Scientific Computation: A Structured Approach Using BSP and MPI, OUP Oxford, 2004. ,
DOI : 10.1093/acprof:oso/9780198529392.001.0001
A Survey of Active Object Languages, ACM Computing Surveys, vol.50, issue.5, pp.1-7639, 2017. ,
DOI : 10.1007/978-3-319-24644-4_5
URL : https://hal.archives-ouvertes.fr/hal-01627936
The Paderborn University BSP (PUB) library, Parallel Computing, vol.29, issue.2, pp.187-207, 2003. ,
DOI : 10.1016/S0167-8191(02)00218-1
Asynchronous and deterministic objects, Proceedings of the 31st ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL '04, pp.123-134, 2004. ,
Part: An asynchronous parallel abstraction for speculative pipeline computations, Coordination Models and Languages, pp.101-120, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01631723
Formal Semantics of a Subset of the Paderborn's BSPlib, 2008 Ninth International Conference on Parallel and Distributed Computing, Applications and Technologies, pp.269-276, 2008. ,
DOI : 10.1109/PDCAT.2008.43
Subset synchronization in BSP computing, pp.242-246, 1998. ,
Multilisp: A language for concurrent symbolic computation, ACM Trans. Program. Lang. Syst, vol.7, issue.4, pp.501-538, 1985. ,
Multi-threaded Active Objects, Lecture Notes in Computer Science, vol.7890, pp.90-104, 2013. ,
DOI : 10.1007/978-3-642-38493-6_7
URL : https://hal.archives-ouvertes.fr/hal-01486037
BSPlib: The BSP programming library, Parallel Computing, vol.24, issue.14, pp.1947-1980, 1998. ,
DOI : 10.1016/S0167-8191(98)00093-3
, , 2013.
Formal Semantics of DRMA-Style Programming in BSPlib, Parallel Processing and Applied Mathematics, pp.1122-1129, 2008. ,
DOI : 10.1007/978-3-540-68111-3_119
StreamIt: A Language for Streaming Applications, Compiler Construction, pp.179-196, 2002. ,
DOI : 10.1007/3-540-45937-5_14
A bridging model for parallel computation, Communications of the ACM, vol.33, issue.8, p.103, 1990. ,
DOI : 10.1145/79173.79181
