Corese : a Corporate Semantic Web Engine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
With the aim of building a Corporate Semantic Web, the content of the documents must be explicitly represented through metadata in order to enable contents-guided search. The Corese engine is dedicated to the querying of corporate semantic webs whose documents are described into RDF annotations. Corese interprets these RDF metadata in the Conceptual Graphs (CG) model in order to exploit the inference capabilities of this formalism. This paper presents our mapping of RDF into CG and its interest in the context of a Corporate Semantic Web.
corese.pdf (192.2 Ko) Télécharger le fichier
hal-01822512 , version 1 (25-06-2018)
  • HAL Id : hal-01822512 , version 1
Olivier Corby, Catherine Faron Zucker. Corese : a Corporate Semantic Web Engine. International Workshop on Real World RDF and Semantic Web Applications, International World Wide Web Conference, May 2002, Hawai, United States. ⟨hal-01822512⟩
198 Consultations
114 Téléchargements
