Benchmarking functional connectome-based predictive models for resting-state fMRI
Abstract : Functional connectomes reveal biomarkers of individual psychological or clinical traits. However, there is great variabil- ity in the analytic pipelines typically used to derive them from rest-fMRI cohorts. Here, we consider a specific type of studies, using predictive models on the edge weights of functional connectomes, for which we highlight the best modeling choices. We systematically study the prediction performances of models in 6 different cohorts and a total of 2 000 individ- uals, encompassing neuro-degenerative (Alzheimer’s, Post-traumatic stress disorder), neuro-psychiatric (Schizophrenia, Autism), drug impact (Cannabis use) clinical settings and psychological trait (fluid intelligence). The typical predic- tion procedure from rest-fMRI consists of three main steps: defining brain regions, representing the interactions, and supervised learning. For each step we benchmark typical choices: 8 different ways of defining regions –either pre-defined or generated from the rest-fMRI data– 3 measures to build functional connectomes from the extracted time-series, and 10 classification models to compare functional interactions across subjects. Our benchmarks summarize more than 240 different pipelines and outline modeling choices that show consistent prediction performances in spite of variations in the populations and sites. We find that regions defined from functional data work best; that it is beneficial to capture between-region interactions with tangent-based parametrization of covariances, a midway between correlations and par- tial correlation; and that simple linear predictors such as a logistic regression give the best prediction. Our work is a step forward to establishing reproducible imaging-based biomarkers for clinical settings.
Type de document :
Pré-publication, Document de travail
2018
Liste complète des métadonnées
https://hal.inria.fr/hal-01824205
Contributeur : Kamalaker Dadi <>
Soumis le : mardi 6 novembre 2018 - 18:14:09
Dernière modification le : vendredi 9 novembre 2018 - 01:12:10
Fichier
neuroimage.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01824205, version 2
Citation
Kamalaker Dadi, Mehdi Rahim, Alexandre Abraham, Darya Chyzhyk, Michael Milham, et al.. Benchmarking functional connectome-based predictive models for resting-state fMRI. 2018. 〈hal-01824205v2〉
Métriques
Consultations de la notice
843
Téléchargements de fichiers
457
