Sparse supernodal solver using block low-rank compression: Design, performance and analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computational Science and Engineering Année : 2018
This paper presents two approaches using a Block Low-Rank (BLR) compression technique to reduce the memory footprint and/or the time-to-solution of the sparse supernodal solver PaStiX. This flat, non-hierarchical, compression method allows to take advantage of the low-rank property of the blocks appearing during the factorization of sparse linear systems, which come from the discretization of partial differential equations. The proposed solver can be used either as a direct solver at a lower precision or as a very robust preconditioner. The first approach, called Minimal Memory, illustrates the maximum memory gain that can be obtained with the BLR compression method, while the second approach, called Just-In-Time, mainly focuses on reducing the computational complexity and thus the time-to-solution. Singular Value Decomposition (SVD) and Rank-Revealing QR (RRQR), as compression kernels, are both compared in terms of factorization time, memory consumption, as well as numerical properties. Experiments on a shared memory node with 24 threads and 128 GB of memory are performed to evaluate the potential of both strategies. On a set of matrices from real-life problems, we demonstrate a memory footprint reduction of up to 4 times using the Minimal Memory strategy and a computational time speedup of up to 3.5 times with the Just-In-Time strategy. Then, we study the impact of configuration parameters of the BLR solver that allowed us to solve a 3D laplacian of 36 million unknowns a single node, while the full-rank solver stopped at 8 million due to memory limitation.
blr.pdf (559.61 Ko) Télécharger le fichier
hal-01824275 , version 1 (27-06-2018)
Grégoire Pichon, Eric Darve, Mathieu Faverge, Pierre Ramet, Jean Roman. Sparse supernodal solver using block low-rank compression: Design, performance and analysis. International Journal of Computational Science and Engineering, 2018, 27, pp.255 - 270. ⟨10.1016/J.JOCS.2018.06.007⟩. ⟨hal-01824275⟩
Collections
CNRS INRIA INRIA2
389 Consultations
500 Téléchargements
