WebBFT: Byzantine Fault Tolerance for Resilient Interactive Web Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Christian Berger
Hans P. Reiser
  • Fonction : Auteur
  • PersonId : 1031369
Byzantine fault tolerant (BFT) applications are usually implemented with dedicated clients that interact with a set of replicas with some BFT protocol. In this paper, we explore the possibility of using web-based clients for interaction with a BFT service. Our contributions address the trustworthy deployment of client code and configuration in a browser-based execution environment (client bootstrapping), the design and implementation of a BFT client within the constraints of a browser-based JavaScript execution environment, and publish-subscribe extensions to the standard request/reply interaction model of BFT state machine model to simplify the implementation of efficient interactive web applications.
469768_1_En_1_Chapter.pdf (1004.34 Ko) Télécharger le fichier
hal-01824640 , version 1 (27-06-2018)
Paternité
Christian Berger, Hans P. Reiser. WebBFT: Byzantine Fault Tolerance for Resilient Interactive Web Applications. 18th IFIP International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2018, Madrid, Spain. pp.1-17, ⟨10.1007/978-3-319-93767-0_1⟩. ⟨hal-01824640⟩
114 Consultations
166 Téléchargements
