Preserving Contract Satisfiability Under Non-monotonic Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
A contracts theory embeds non-monotonic composition (with respect to implementation) if the fact that a composition of two components implements a specification $$\mathcal {S}$$ does not generally follow from one of these components implementing $$\mathcal {S}$$. In contrast to monotonic composition, non-monotonic composition offers the additional expressiveness of specifying properties that only hold locally for a component since non-monotonic composition does not enforce all properties to be preserved when composing. Despite that this additional expressiveness is clearly needed, it implies that cases where monotony is indeed desired needs to be managed explicitly. The present paper elaborates on this topic by introducing a contracts theory embedding non-monotonic composition, and exploring conditions for ensuring monotonic composition in the context of this theory.
469043_1_En_10_Chapter.pdf (315.26 Ko) Télécharger le fichier
hal-01824811 , version 1 (27-06-2018)
Paternité
Jonas Westman, Mattias Nyberg. Preserving Contract Satisfiability Under Non-monotonic Composition. 38th International Conference on Formal Techniques for Distributed Objects, Components, and Systems (FORTE), Jun 2018, Madrid, Spain. pp.181-195, ⟨10.1007/978-3-319-92612-4_10⟩. ⟨hal-01824811⟩
55 Consultations
30 Téléchargements
