Motion analysis in oceanographic satellite images using multiscale methods and the energy cascade, Pattern Recognition, vol.43, issue.10, pp.3591-3604, 2010. ,
DOI : 10.1016/j.patcog.2010.04.011
URL : https://hal.archives-ouvertes.fr/inria-00423748
The Local Structure of Turbulence in Incompressible Viscous Fluid for Very Large Reynolds Numbers, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.434, issue.1890, pp.9-13, 1991. ,
DOI : 10.1098/rspa.1991.0075
Turbulence: The Legacy of A, 1995. ,
DOI : 10.1017/CBO9781139170666
On the singularity structure of fully developed turbulence, " in Turbulence and Predictability in Geophysical Fluid Dynamics and ClimateDynamics, pp.84-88, 1985. ,
Budgeting sinks and sources of CO 2 in the coastal ocean: Diversity of ecosystems counts, Geophys. Res. Lett, vol.32, pp.14601-14611, 2005. ,
Microcanonical multifractal formalism???a geometrical approach to multifractal systems: Part I. Singularity analysis, Journal of Physics A: Mathematical and Theoretical, vol.41, issue.1, p.15501, 2008. ,
DOI : 10.1088/1751-8113/41/1/015501
URL : https://hal.archives-ouvertes.fr/hal-00937370
Inferring missing data in satellite chlorophyll maps using turbulent cascading, Remote Sensing of Environment, vol.112, issue.12, pp.4242-4260, 2008. ,
DOI : 10.1016/j.rse.2008.07.010
URL : https://hal.archives-ouvertes.fr/hal-00402483
Ocean Turbulent Dynamics at Superresolution From Optimal Multiresolution Analysis and Multiplicative Cascade, IEEE Transactions on Geoscience and Remote Sensing, vol.53, issue.11, pp.6274-6285, 2015. ,
DOI : 10.1109/TGRS.2015.2436431
URL : https://hal.archives-ouvertes.fr/hal-01166170
Reconstruction of super-resolution ocean pCO 2 and air?sea fluxes of CO 2 from satellite imagery in the southeastern Atlantic, Biogeosciences, vol.125229, issue.17, pp.5229-5245, 2015. ,
Improving time and space resolution of SMOS salinity maps using multifractal fusion, Remote Sensing of Environment, vol.180, pp.246-263, 2016. ,
DOI : 10.1016/j.rse.2016.02.038
Data-based estimates of the ocean carbon sink variability?First results of the Surface Ocean pCO 2 Mapping intercomparison (SOCOM) Available: https://www.biogeosciences, Biogeosciences, vol.12127251, issue.23, pp.7251-7278, 2015. ,
The reinvigoration of the Southern Ocean carbon sink, Science, vol.349, issue.6253, pp.1221-1224, 2015. ,
DOI : 10.1038/nature12945
Empirical methods for the estimation of Southern Ocean CO<sub>2</sub>: support vector and random forest regression, Biogeosciences, vol.14, issue.23, pp.5551-5569, 2017. ,
DOI : 10.1002/2016GB005541
URL : https://doi.org/10.5194/bg-2017-215
Budgeting sinks and sources of CO 2 in the coastal ocean: Diversity of ecosystems counts, Geophys. Res. Lett, vol.32, issue.14, p.14601, 2005. ,
The changing carbon cycle of the coastal ocean, Nature, vol.433, issue.7478, pp.61-70, 2013. ,
DOI : 10.1038/nature03191
Nitrogen transfers off Walvis Bay: A 3-D coupled physical/biogeochemical modeling approach in the Namibian upwelling system The Operational Sea Surface Temperature and Sea Ice Analysis (OSTIA) system, Biogeosciences Remote Sens. Environ, vol.1017, issue.116, pp.4117-4135, 2012. ,
Climatological mean and decadal change in surface ocean pCO 2 , and net sea?air CO 2 flux over the global oceans, Deep Sea Res. II, Top. Stud. Oceanogr, vol.56, pp.8-10, 2009. ,
DOI : 10.1016/j.dsr2.2008.12.009
URL : https://hal.archives-ouvertes.fr/hal-00763263
An atmospheric perspective on North American carbon dioxide exchange: CarbonTracker, Proc. Nat. Acad. Sci. USA, pp.18925-18930, 2007. ,
DOI : 10.5194/acp-4-523-2004
URL : http://www.pnas.org/content/104/48/18925.full.pdf
Constraining global air-sea gas exchange for CO 2 with recent bomb 14 C measurements, Global Biogeochem. Cycles, vol.21, issue.2, p.2015, 2007. ,
DOI : 10.1029/2006gb002784
URL : http://onlinelibrary.wiley.com/doi/10.1029/2006GB002784/pdf
Carbon dioxide in water and seawater: the solubility of a non-ideal gas, Marine Chemistry, vol.2, issue.3, pp.203-215, 1974. ,
DOI : 10.1016/0304-4203(74)90015-2
Evidence for Submesoscale Barriers to Horizontal Mixing in the Ocean from Current Measurements and Aerial Photographs, Journal of Physical Oceanography, vol.39, issue.8, pp.1975-1983, 2009. ,
DOI : 10.1175/2009JPO4116.1
A gridded sea surface salinity data set for the tropical Pacific with sample applications (1950???2008), Deep Sea Research Part I: Oceanographic Research Papers, vol.58, issue.1, pp.38-48, 1950. ,
DOI : 10.1016/j.dsr.2010.11.002
URL : https://hal.archives-ouvertes.fr/hal-00605675
Modeling of atmospheric transport of chemical species in the polar regions, 2012 IEEE International Geoscience and Remote Sensing Symposium, pp.6047-6050, 2012. ,
DOI : 10.1109/IGARSS.2012.6352228
Global sea?air CO 2 flux based on climatological surface ocean pCO 2 , and seasonal biological and temperature effects, Deep Sea Res. II, Top. Stud. Oceanogr, vol.49, pp.9-10, 2002. ,
DOI : 10.1016/s0967-0645(02)00003-6
URL : https://hal.archives-ouvertes.fr/hal-01282876
An update to the surface ocean ,
URL : https://hal.archives-ouvertes.fr/hal-00873454
, Available: https://www.earth-syst-scidata, Atlas Earth Syst. Sci. Data, vol.669, issue.2 16, pp.69-90, 2014.
Carbon dioxide fluxes in the Benguela upwelling system during winter and spring: A comparison between, Deep Sea Res. II, Top. Stud. Oceanogr, vol.56, pp.8-10, 2005. ,
Seasonal variability of f CO 2 in the Angola-Benguela region, Prog. Oceanogr, vol.83, pp.1-4, 2009. ,
Multifractal Method for the Instantaneous Evaluation of the Stream Function in Geophysical Flows, Physical Review Letters, vol.15, issue.10, p.104502, 2005. ,
DOI : 10.1175/1520-0426(1998)015<0522:AIMMOM>2.0.CO;2
An Optimized Algorithm for the Evaluation of Local Singularity Exponents in Digital Signals, Proc. 14th Int, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00581057
ON OPTIMAL WAVELET BASES FOR THE REALIZATION OF MICROCANONICAL CASCADE PROCESSES, International Journal of Wavelets, Multiresolution and Information Processing, vol.95, issue.01, pp.35-61, 2011. ,
DOI : 10.1006/acha.2000.0350
URL : https://hal.archives-ouvertes.fr/inria-00582372
