A method for computing curved 2D and 3D meshes via the linear elasticity analogy: preliminary results, 2012. ,
DOI : 10.1002/fld.3932
URL : https://hal.archives-ouvertes.fr/hal-00728850
Variational tetrahedral meshing, In ACM Trans. Graph, vol.24, pp.617-625, 2005. ,
DOI : 10.1145/1186822.1073238
URL : https://hal.archives-ouvertes.fr/inria-00226418
Mesh approximation using a volume-based metric, Paciï¿¿c Conf. on Computer Graphics and Applications, pp.292-301, 1999. ,
DOI : 10.1109/pccga.1999.803373
Optimal Point Placement for Mesh Smoothing, J. Algorithms, vol.30, pp.302-322, 1999. ,
DOI : 10.1006/jagm.1998.0984
URL : http://www.ics.uci.edu/~eppstein/pubs/AmeBerEpp-SODA-97.pdf
The p-version of the Finite Element Method, SIAM J. Num. Anal, vol.18, pp.515-545, 1981. ,
Animation of Deformable Bodies with Quadratic Bézier Finite Elements, ACM Trans. Graph, vol.33, issue.3, p.27, 2014. ,
DOI : 10.1145/2567943
Comparison of algorithms for anisotropic meshing and adaptive reï¿¿nement, INRIA, 2006. ,
Optimal Voronoi Tessellations with Hessian-based Anisotropy, ACM Trans. Graph, vol.35, p.242, 2016. ,
DOI : 10.1145/2980179.2980245
URL : https://hal.archives-ouvertes.fr/hal-01376243
A Bézier-based Approach to Unstructured Moving Meshes, Symp, pp.310-319, 2004. ,
DOI : 10.1145/997817.997864
A Simple Geometric Model for Elastic Deformations, ACM Trans. Graph, vol.29, p.38, 2010. ,
DOI : 10.1145/1833351.1778775
URL : http://www.cs.jhu.edu/%7Emisha/ReadingSeminar/Papers/Chao10.pdf
Mesh Smoothing Schemes based on Optimal Delaunay Triangulations, Int. Meshing Roundtable, pp.109-120, 2004. ,
DOI : 10.1016/j.cma.2010.11.007
Eï¿¿cient mesh optimization schemes based on optimal Delaunay triangulations, Computer Methods in Applied Mechanics and Engineering, vol.200, pp.967-984, 2011. ,
, Optimal delaunay triangulations. J. Computational Mathematics, pp.299-308, 2004.
Revisiting Optimal Delaunay Triangulation for 3D Graded Mesh Generation, SIAM J. Sci. Comput, vol.36, pp.930-954, 2014. ,
DOI : 10.1137/120875132
URL : https://hal.archives-ouvertes.fr/hal-01101627
, Sliver Exudation. J. ACM, vol.47, pp.883-904, 2000.
Delaunay Mesh Generation, 2012. ,
DOI : 10.1201/b12987
Composing Bézier Simplexes, ACM Trans. Graph, vol.7, issue.3, pp.198-221, 1988. ,
Centroidal Voronoi tesselations, SIAM Rev, vol.41, pp.637-676, 1999. ,
Tetrahedral Mesh Improvement using Swapping and Smoothing, Int. J. Numer. Meth. Engng, vol.40, pp.3979-4002, 1997. ,
DOI : 10.1002/(sici)1097-0207(19971115)40:21<3979::aid-nme251>3.0.co;2-9
Anisotropic Simplicial Meshing Using Local Convex Functions, ACM Trans. Graph, vol.33, 2014. ,
DOI : 10.1145/2661229.2661235
Quality Tetrahedral Mesh Smoothing via Boundary-optimized Delaunay Triangulation, Comput. Aided Geom. Design, vol.29, pp.707-721, 2012. ,
High-order mesh generation on CAD geometries, Int. Conf. on Adaptive Modeling & Simulation, pp.301-312, 2013. ,
The Generation of Valid Curvilinear Meshes, Notes on Numerical Fluid Mechanics and Multidisciplinary Design, vol.128, pp.15-39, 2015. ,
Eigen v3, 2018. ,
Geometrical validity of curvilinear ï¿¿nite elements, J. Comp. Phys, vol.233, pp.359-372, 2013. ,
HighOrder Mesh Curving Using WCN Mesh Optimization, 46th AIAA Fluid Dynamics Conference, 2016. ,
Algebraic Mesh Quality Metrics, SIAM J. Sci. Comput, vol.23, pp.193-218, 2001. ,
On Centroidal Voronoi Tessellation-Energy Smoothness and Fast Computation, ACM Trans. Graph, vol.28, p.101, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00547936
Optimal 3D Highly Anisotropic Mesh Adaptation Based on the Continuous Mesh Framework, Int. Meshing Roundtable, pp.575-594, 2009. ,
p-Version Mesh Generation Issues, Int. Mesh Roundtable, pp.343-354, 2002. ,
Discrete Diï¿¿erential-Geometry Operators for Triangulated 2-Manifolds, pp.35-57, 2003. ,
Interactive Physically-based Shape Editing, In Symp. Solid Phys. Modeling, pp.79-89, 2008. ,
Piecewise linear best L 2 approximation on triangulations, pp.499-502, 1986. ,
Curved Mesh Generation and Mesh Reï¿¿nement using Lagrangian Solid Mechanics, 1997. ,
Bounding the inï¿¿uence of domain parameterization and knot spacing on numerical stability in Isogeometric Analysis, Comput. Methods in Appl. Mech. Eng, vol.268, pp.589-613, 2014. ,
Computing Discrete Minimal Surfaces and Their Conjugates, Experimental Mathematics, vol.2, pp.15-36, 1993. ,
Geometry of the squared distance function to curves and surfaces, Visualization and mathematics III, pp.221-242, 2003. ,
Meshing 3D Domains Bounded by Piecewise Smooth Surfaces, pp.443-460, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00681581
A BernsteinBézier Based Approach to Soft Tissue Simulation, Computer Graphics Forum, vol.17, pp.285-294, 1998. ,
An augmented Lagrangian formulation to impose boundary conditions for distortion based mesh moving and curving, 2017. ,
, Numerical integration (quadrature, cubature) in Python, 2018.
Tetrahedral Mesh Generation by Delaunay Reï¿¿nement, Symp. on Comp. Geometry, pp.86-95, 1998. ,
What is a Good Linear Element? Interpolation, Conditioning, and Quality Measures, Int. Meshing Roundtable, pp.115-126, 2002. ,
Accurate Surface Embedding for Higher Order Finite Elements, Symp. Comp. Anim, pp.187-192, 2013. ,
, CGAL Editorial Board, 2017.
Interleaving Delaunay reï¿¿nement and optimization for practical isotropic tetrahedron mesh generation, ACM Trans. Graph, vol.28, 2009. ,
Interactive deformable models with quadratic bases in Bernstein-Bézier-form, The Visual Computer, vol.27, pp.473-483, 2011. ,
On the identiï¿¿cation of symmetric quadrature rules for ï¿¿nite element methods, Comp. & Math. Appl, vol.69, pp.1232-1241, 2015. ,
Comparison of 2D curving methods with modal shape functions and a piecewise linear target mesh, In ACM Trans. Graph, vol.37, issue.4, 2017. ,
