A note on distributed finite-time observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2018
The robust distributed estimation for a class of time-invariant plants is achieved via a finite-time observer, its error reaching zero after a finite time in the absence of perturbation. Two types of robustness are also shown. First, input-to-state stability with respect to measurement noises and additive perturbations is proven. Second, we demonstrate that the estimation error stays bounded in the presence of known transmission delays.
DistributedObserver.pdf (366.29 Ko) Télécharger le fichier
hal-01827041 , version 1 (01-07-2018)
hal-01827041 , version 2 (07-11-2019)
Haik Silm, Rosane Ushirobira, Denis Efimov, Jean-Pierre Richard, Wim Michiels. A note on distributed finite-time observers. IEEE Transactions on Automatic Control, 2018, ⟨10.1109/TAC.2018.2838042⟩. ⟨hal-01827041v1⟩
234 Consultations
310 Téléchargements
