Alignment Cubes: Interactive Visual Exploration and Evaluation of Multiple Ontology Alignments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2017
The quality of ontology alignments is evaluated by comparing to reference alignments and calculating general measures, i.e., precision, recall and F-measure. These measures, however, only provide an overall assessment of the alignments' quality, but do not reveal differences and commonalities between alignments at a finer-grained level such as, e.g., regions or individual mappings. This demands comparative exploration of alignments at different levels of granularity. Furthermore, reference alignments to compare to are often unavailable, which makes such comparative evaluation even more important. To address this issue, we introduce Alignment Cubes which supports efficient interactive visual exploration of multiple alignments at different granularity levels.
paper496.pdf (182.94 Ko) Télécharger le fichier
hal-01827794 , version 1 (14-07-2018)
  • HAL Id : hal-01827794 , version 1
Valentina Ivanova, Benjamin Bach, Emmanuel Pietriga, Patrick Lambrix. Alignment Cubes: Interactive Visual Exploration and Evaluation of Multiple Ontology Alignments. Proceedings of the ISWC 2017 Posters & Demonstrations Track: Collected Abstracts, Oct 2017, Vienna, Austria. . ⟨hal-01827794⟩
274 Consultations
43 Téléchargements
