On Finite-Time Robust Stabilization via Nonlinear State Feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2018
A nonlinear control law is designed for finite-time stabilization of a chain of integrators. The method is based on Implicit Lyapunov Function (ILF) technique and homogeneity properties. The scheme of control parameters selection is presented by a Linear Matrix Inequality (LMI). The method is simple in implementation and does not assume on-line procedure for computation of the ILF value at the current state that is an improvement with respect to [9], [13]. The control law is presented in an explicit form and allows to find the values of all control parameters, that make the solution one of the most constructive. The theoretical results are supported by numerical example.
Automatique
fts_final.pdf (506.76 Ko) Télécharger le fichier
hal-01830102 , version 1 (04-07-2018)
Konstantin Zimenko, Andrey Polyakov, Denis Efimov. On Finite-Time Robust Stabilization via Nonlinear State Feedback. International Journal of Robust and Nonlinear Control, 2018, 28 (16), pp.4951-4965. ⟨10.1002/rnc.4292⟩. ⟨hal-01830102⟩
Collections
INRIA INRIA2
96 Consultations
166 Téléchargements
