, Figure 3. Transients of the system states for the finite, time control
, Figure 4. The system input u for the finite-time control presented in
, the finite-time control (42) Figure 6. The system input u for accelerated control in the form (42) Consider the system (1) for n = 3 in the case of matched disturbances with d 1 (t, x) = d 2 (t, x) = 0, d 3 (t, x) The parameters of the control (16) were selected solving the LMI REFERENCES, Figure 5. Transients of the system states for
Stabilization of chain of integrators with arbitrary order in finite-time, 2015 54th IEEE Conference on Decision and Control (CDC), 2015. ,
DOI : 10.1109/CDC.2015.7402942
URL : https://hal.archives-ouvertes.fr/hal-01212600
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02849435
Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
DOI : 10.1137/0324047
Finite-Time Stability and Stabilization: State of the Art, Lecture Notes in Control and Information Sciences, vol.334, pp.23-41, 2006. ,
DOI : 10.1007/11612735_2
A continuous-time observer which converges in finite time, IEEE Transactions on Automatic Control, vol.47, issue.7, pp.1202-1204, 2002. ,
DOI : 10.1109/TAC.2002.800673
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Global Finite-Time Observers for Lipschitz Nonlinear Systems, IEEE Transactions on Automatic Control, vol.56, issue.2, pp.418-424, 2011. ,
DOI : 10.1109/TAC.2010.2088610
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.42, issue.10 ,
DOI : 10.1201/9781420065619
URL : https://hal.archives-ouvertes.fr/hal-01160052
, Robust. Nonlinear Control, vol.26, issue.1, pp.69-90, 2016.
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
Finite-time output stabilization of the double integrator, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), pp.5906-5911, 2012. ,
DOI : 10.1109/CDC.2012.6426565
URL : https://hal.archives-ouvertes.fr/hal-01056207
Stability notions and Lyapunov functions for sliding mode control systems, Journal of the Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014. ,
DOI : 10.1016/j.jfranklin.2014.01.002
URL : https://hal.archives-ouvertes.fr/hal-00942319
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Methods of A.M. Lyapunov and Their Applications, Noordhoff Ltd, 1964. ,
Nilpotent Approximations of Control Systems and Distributions, SIAM Journal on Control and Optimization, vol.24, issue.4, p.731736, 1986. ,
DOI : 10.1137/0324045
On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica, vol.1, issue.8088, 1958. ,
Lyapunov Functions and Stability in Control Theory, 2005. ,
Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
URL : https://www1.rmr.tu-darmstadt.de/pdf/flemming2004.pdf
A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, issue.12, pp.1159-1167, 2013. ,
DOI : 10.1016/j.sysconle.2013.09.004
URL : https://hal.archives-ouvertes.fr/hal-00877148
Semi-global finite-time observers for nonlinear systems, Automatica, vol.44, issue.12, pp.3152-3156, 2008. ,
DOI : 10.1016/j.automatica.2008.05.015
Finite-time stabilization of uncertain MIMO systems, 53rd IEEE Conference on Decision and Control, pp.4753-4758, 2014. ,
DOI : 10.1109/CDC.2014.7040130
Accelerated High-Order MIMO Sliding Mode control, 2014 13th International Workshop on Variable Structure Systems (VSS), pp.1-6, 2014. ,
DOI : 10.1109/VSS.2014.6881095
Supervisory acceleration of convergence for homogeneous systems, International Journal of Control, vol.1, 2017. ,
DOI : 10.1007/978-3-642-84379-2
URL : https://hal.archives-ouvertes.fr/hal-01411088
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004. ,
DOI : 10.1137/S0363012903425593
Discontinuous systems: Lyapunov analysis and robust synthesis under uncertainty conditions, 2009. ,
Nonlinear Control Systems II, 1999. ,
DOI : 10.1007/978-1-4471-0549-7
On homogeneity and its application in sliding mode control, Journal of the Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014. ,
DOI : 10.1016/j.jfranklin.2014.01.007
URL : https://hal.archives-ouvertes.fr/hal-00942326
On an extension of homogeneity notion for differential inclusions, 2013 European Control Conference (ECC), pp.2204-2209, 2013. ,
DOI : 10.23919/ECC.2013.6669525
URL : https://hal.archives-ouvertes.fr/hal-00801818
Introduction to calculus and analysis, 2000. ,
