Crowd Counting via Scale-Adaptive Convolutional Neural Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Lu Zhang
  • Fonction : Auteur
  • PersonId : 764723
  • IdRef : 200027433
Qiaobo Chen
  • Fonction : Auteur
  • PersonId : 1034089
The task of crowd counting is to automatically estimate the pedestrian number in crowd images. To cope with the scale and perspective changes that commonly exist in crowd images, state-of-the-art approaches employ multi-column CNN architectures to regress density maps of crowd images. Multiple columns have different receptive fields corresponding to pedestrians (heads) of different scales. We instead propose a scale-adaptive CNN (SaCNN) architecture with a backbone of fixed small receptive fields. We extract feature maps from multiple layers and adapt them to have the same output size; we combine them to produce the final density map. The number of people is computed by integrating the density map. We also introduce a relative count loss along with the density map loss to improve the network generalization on crowd scenes with few pedestrians , where most representative approaches perform poorly on. We conduct extensive experiments on the ShanghaiTech, UCF_CC_50 and WorldExpo'10 datasets as well as a new dataset SmartCity that we collect for crowd scenes with few people. The results demonstrate significant improvements of SaCNN over the state-of-the-art.
wacv2018shi.pdf (1.48 Mo) Télécharger le fichier
hal-01830946 , version 1 (05-07-2018)
Lu Zhang, Miaojing Shi, Qiaobo Chen. Crowd Counting via Scale-Adaptive Convolutional Neural Network. WACV 2018 - IEEE Winter Conference on Applications of Computer Vision, Mar 2018, Lake Tahoe, United States. pp.1-9, ⟨10.1109/WACV.2018.00127⟩. ⟨hal-01830946⟩
340 Consultations
939 Téléchargements
