Ethereum Query Language - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (1) , (1) , (1)
1
Blockchains store a massive amount of heterogeneous data which will only grow in time. When searching for data on the Ethereum platform, one is required to either access the records (blocks) directly by using a unique identifier, or sequentially search several records to find the desired information. Therefore, we propose the Ethereum Query Language (EQL), a query language that allows users to retrieve information from the blockchain by writing SQL-like queries. The queries provide a rich syntax to specify data elements to search information scattered through several records. We claim that EQL makes it easier to search, acquire, format, and present information from the blockchain.
Braga18b-WETSEB-Query.pdf (913.84 Ko) Télécharger le fichier
Dates and versions
hal-01831084 , version 1 (05-07-2018)
Identifiers
Cite
Santiago Bragagnolo, Henrique S C Rocha, Marcus Denker, Stéphane Ducasse. Ethereum Query Language. WETSEB 2018 - 1st International Workshop on Emerging Trends in Software Engineering for Blockchain, May 2018, Gothenburg, Sweden. ⟨10.1145/3194113.3194114⟩. ⟨hal-01831084⟩
276 View
888 Download
Share
