Counting in the wild, ECCV, 2016. ,
Crowdnet: a deep convolutional network for dense crowd counting, ACM MM, 2016. ,
Unsupervised bayesian detection of independent motion in crowds, CVPR, vol.1, 2006. ,
Scale aggregation network for accurate and efficient crowd counting, ECCV, vol.7, 2006. ,
Privacy preserving crowd monitoring: Counting people without people models or tracking, CVPR, 2006. ,
Counting people with low-level features and bayesian regression, IEEE Transactions on Image Processing, vol.21, issue.4, pp.2160-2177, 2012. ,
Shaogang Gong, and Tony Xiang. Feature mining for localised crowd counting, BMVC, vol.1, 2012. ,
Histograms of oriented gradients for human detection, CVPR, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00548512
Rahul Nair, and Fred A Hamprecht. Learning to count with regression forest and structured labels, ICPR, vol.1, p.3, 2012. ,
Complete solution classification for the perspective-three-point problem, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.8, pp.930-943, 2003. ,
Body structure aware deep crowd counting, IEEE Transactions on Image Processing, vol.27, issue.3, pp.1049-1059, 2008. ,
Multi-source multi-scale counting in extremely dense crowd images, CVPR, p.6, 2004. ,
Detecting humans in dense crowds using locally-consistent scale prior and global occlusion reasoning, TPAMI, vol.37, issue.10, 1986. ,
Caffe: Convolutional architecture for fast feature embedding, ACM MM, 2014. ,
Counting pedestrians in crowds using viewpoint invariant training, BMVC, vol.1, 2005. ,
Learning to count objects in images, NIPS, vol.1, p.3, 2010. ,
Csrnet: Dilated convolutional neural networks for understanding the highly congested scenes, CVPR, 2007. ,
Estimation of number of people in crowded scenes using perspective transformation, TSMC-A, vol.31, issue.6, pp.645-654, 2001. ,
Decidenet: Counting varying density crowds through attention guided detection and density estimation, CVPR, vol.2, 2018. ,
Leveraging unlabeled data for crowd counting by learning to rank, CVPR, 2007. ,
Point in, box out: Beyond counting persons in crowds, CVPR, vol.1, 2019. ,
Shaogang Gong, and Tao Xiang. Crowd counting and profiling: Methodology and evaluation, Modeling, Simulation and Visual Analysis of Crowds, vol.2, p.3, 2013. ,
Crowd counting via scale-adaptive convolutional neural network, In WACV, issue.2, 2018. ,
On the efficacy of texture analysis for crowd monitoring, SIB-GRAPI, 1998. ,
Towards perspective-free object counting with deep learning, ECCV, 2008. ,
A mrf-based approach for real-time subway monitoring, CVPR, 2001. ,
Counting crowded moving objects, CVPR, vol.1, 2006. ,
, Iterative crowd counting. ECCV, 2008.
Distributed data fusion for real-time crowding estimation, Signal Processing, vol.53, issue.1, pp.47-63, 1996. ,
Crowd counting using multiple local features, DICTA, vol.1, 2009. ,
Switching convolutional neural network for crowd counting, CVPR, 2008. ,
Crowd counting via adversarial cross-scale consistency pursuit, CVPR, vol.2, p.7, 2018. ,
Crowd counting with deep negative correlation learning, CVPR, 2018. ,
Very deep convolutional networks for large-scale image recognition, ICLR, vol.4, p.7, 2015. ,
Cnn-based cascaded multi-task learning of high-level prior and density estimation for crowd counting, AVSS, issue.2, 2017. ,
Generating highquality crowd density maps using contextual pyramid cnns, ICCV, vol.7, 2003. ,
End-to-end people detection in crowded scenes, CVPR, 2016. ,
Rapid object detection using a boosted cascade of simple features, CVPR, 2001. ,
Detecting pedestrians using patterns of motion and appearance, IJCV, vol.63, issue.2, pp.153-161, 2003. ,
Learning to count with cnn boosting, ECCV, 2016. ,
Deep people counting in extremely dense crowds, ACM MM, 2015. ,
Automatic adaptation of a generic pedestrian detector to a specific traffic scene, CVPR, 2011. ,
Image quality assessment: from error visibility to structural similarity, IEEE transactions on image processing, vol.13, issue.4, pp.600-612, 2004. ,
Detection of multiple, partially occluded humans in a single image by bayesian combination of edgelet part detectors, ICCV, vol.1, 2005. ,
Spatiotemporal modeling for crowd counting in videos, ICCV, vol.2, 2017. ,
Cross-scene crowd counting via deep convolutional neural networks, CVPR, vol.7, 2006. ,
Single-image crowd counting via multi-column convolutional neural network, CVPR, vol.7, 2006. ,
Crossing-line crowd counting with two-phase deep neural networks, In ECCV, issue.2, 2016. ,
