Imprecise computations, Proc. IEEE, pp.83-94, 1994. ,
DOI : 10.1109/5.259428
URL : http://b2.cvl.iis.u-tokyo.ac.jp/mva/proceedings/2007CD/papers/13-04.pdf
Mapping on multi/many-core systems, Proceedings of the 50th Annual Design Automation Conference on, DAC '13, pp.1-10, 2013. ,
DOI : 10.1145/2463209.2488734
Energy-aware scheduling mandatory/optional tasks in multicore real-time systems, International Transactions in Operational Research, vol.90, issue.10, pp.173-198, 2017. ,
DOI : 10.1016/j.jss.2013.12.032
Minimizing Energy Consumption for Frame-Based Tasks on Heterogeneous Multiprocessor Platforms, IEEE Transactions on Parallel and Distributed Systems, vol.26, issue.3, pp.810-823, 2015. ,
DOI : 10.1109/TPDS.2014.2313338
Energy optimization for real-time multiprocessor system-on-chip with optimal DVFS and DPM combination, ACM Transactions on Embedded Computing Systems, vol.13, issue.3s, pp.1-111, 2014. ,
DOI : 10.1145/513918.513966
URL : http://mediatum.ub.tum.de/doc/1281531/document.pdf
Energy-efficient task scheduling for DVFS-enabled heterogeneous computing systems using a linear programming approach, 2016 IEEE 35th International Performance Computing and Communications Conference (IPCCC), pp.1-8, 2016. ,
DOI : 10.1109/PCCC.2016.7820647
Energyaware real-time task scheduling in multiprocessor systems using a hybrid genetic algorithm, Electron, vol.6, issue.2, 2017. ,
DOI : 10.3390/electronics6020040
URL : http://www.mdpi.com/2079-9292/6/2/40/pdf
A Logic-Based Benders Decomposition Approach for Mapping Applications on Heterogeneous Multicore Platforms, ACM Transactions on Embedded Computing Systems, vol.15, issue.1, pp.1-1928 ,
DOI : 10.1109/71.993206
Classification, customization, and characterization: using MILP for task allocation and scheduling, 2006. ,
Simultaneous task allocation, scheduling and voltage assignment for multiple-processors-core systems using mixed integer nonlinear programming, Proc. IEEE ISCAS, pp.309-312, 2003. ,
Energy-Aware Task Scheduling on Heterogeneous NoC-Based MPSoCs, 2017 IEEE International Conference on Computer Design (ICCD), pp.165-168, 2017. ,
DOI : 10.1109/ICCD.2017.33
Energy- and reliability-aware task scheduling onto heterogeneous MPSoC architectures, The Journal of Supercomputing, vol.52, issue.12, pp.265-289, 2012. ,
DOI : 10.1145/337292.337436
An Efficient Biobjective Heuristic for Scheduling Workflows on Heterogeneous DVS-Enabled Processors, Journal of Applied Mathematics, vol.73, issue.12, pp.1-15, 2014. ,
DOI : 10.1109/71.80160
URL : http://doi.org/10.1155/2014/370917
Quasi-Static Assignment of Voltages and Optional Cycles in Imprecise-Computation Systems With Energy Considerations, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.14, issue.10, pp.1117-1129, 2006. ,
DOI : 10.1109/TVLSI.2006.884152
Maximizing rewards for real-time applications with energy constraints, ACM Transactions on Embedded Computing Systems, vol.2, issue.4, pp.537-559, 2003. ,
DOI : 10.1145/950162.950166
URL : http://www.cs.pitt.edu/PARTS/papers/Rusu-RT_Rewards.ps
Dynamic scheduling of imprecisecomputation tasks in maximizing QoS under energy constraints for embedded systems, Proc. IEEE ASP-DAC, pp.452-455, 2008. ,
Energy-adaptive scheduling of imprecise computation tasks for QoS optimization in realtime MPSoC systems, Proc. IEEE DATE, pp.1402-1407, 2017. ,
DOI : 10.23919/date.2017.7927212
Cost-constrained qos optimization for approximate computation real-time tasks in heterogeneous MPSoCs Decomposed task mapping to maximize QoS in energy-constrained real-time multicores, Proc. IEEE ICCD, pp.1-14, 2017. ,
DOI : 10.1109/tcad.2017.2772896
Dynamic Scheduling of Imprecise-Computation Tasks on Real-Time Embedded Multiprocessors, 2013 IEEE 16th International Conference on Computational Science and Engineering, pp.770-777, 2013. ,
DOI : 10.1109/CSE.2013.118
Using bioinspired metaheuristics to solve reward-based energy-aware mandatory/optional realtime tasks scheduling, Proc. IEEE SBESC, pp.132-135, 2015. ,
DOI : 10.1109/sbesc.2015.32
Combined dynamic voltage scaling and adaptive body biasing for lower power microprocessors under dynamic workloads, Proc. IEEE ICCAD, pp.721-725, 2002. ,
DOI : 10.1145/774572.774678
URL : http://www.eecs.umich.edu/eecs/cse/honors/pdfs/01167611.pdf
Leakage aware dynamic voltage scaling for real-time embedded systems, Proceedings of the 41st annual conference on Design automation , DAC '04, pp.275-280, 2004. ,
DOI : 10.1145/996566.996650
URL : http://www.cs.york.ac.uk/rts/docs/SIGDA-Compendium-1994-2004/papers/2004/dac04/pdffiles/p275.pdf
Non-convex mixed-integer nonlinear programming: A survey, Surveys in Operations Research and Management Science, vol.17, issue.2, pp.97-106, 2012. ,
DOI : 10.1016/j.sorms.2012.08.001
URL : http://www.lancaster.ac.uk/staff/letchfoa/articles/minlp-survey.pdf
Temperature-Aware Scheduling and Assignment for Hard Real-Time Applications on MPSoCs, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.19, issue.10, pp.1884-1897, 2011. ,
DOI : 10.1109/TVLSI.2010.2058873
URL : http://www.cse.nd.edu/Reports/2009/TR-2009-06.pdf
Partitioning procedures for solving mixed-variables programming problems, Numerische Mathematik, vol.38, issue.1, pp.238-252, 1962. ,
DOI : 10.1007/BF01386316
Joint Base Station Association and Power Control via Benders' Decomposition, IEEE Transactions on Wireless Communications, vol.12, issue.4, pp.1651-1665, 2013. ,
DOI : 10.1109/TWC.2013.022113.120470
Convex optimization, 2004. ,
A Modified Benders' Partitioning Algorithm for Mixed Integer Programming, Management Science, vol.24, issue.3, pp.312-319, 1977. ,
DOI : 10.1287/mnsc.24.3.312
On the complexity of integer programming, Journal of the ACM, vol.28, issue.4, pp.765-768, 1981. ,
DOI : 10.1145/322276.322287
The feasibility pump, Mathematical Programming, vol.106, issue.1, pp.91-104, 2005. ,
DOI : 10.1007/BFb0120691
Cross-Layer Congestion Control, Routing and Scheduling Design in Ad Hoc Wireless Networks, Proceedings IEEE INFOCOM 2006. 25TH IEEE International Conference on Computer Communications, pp.1-13, 2006. ,
DOI : 10.1109/INFOCOM.2006.142
Sensor Selection via Convex Optimization, IEEE Transactions on Signal Processing, vol.57, issue.2, pp.451-462, 2009. ,
DOI : 10.1109/TSP.2008.2007095
URL : http://www.sal.ufl.edu/eel6935/2008/sensor_selection.pdf
A family of subgradient-based methods for convex optimization problems in a unifying framework, Optimization Methods and Software, vol.27, issue.5, pp.952-982, 2016. ,
DOI : 10.1007/s10107-010-0394-2
Branch and bound methods, pp.1-11, 2007. ,
Communication-aware branch and bound with cluster-based latency-constraint mapping technique on network-on-chip, The Journal of Supercomputing, vol.39, issue.25, pp.2283-2309, 2016. ,
DOI : 10.1145/278241.278309
URL : https://hal.archives-ouvertes.fr/hal-01499095
A comparison of optimal methods for local access uncapacitated network design, Annals of Operations Research, vol.106, issue.1/4, pp.263-286, 2001. ,
DOI : 10.1023/A:1014569927266
Real-time low-power task mapping in Networks-on-Chip, 2013 IEEE Computer Society Annual Symposium on VLSI (ISVLSI), pp.14-19, 2013. ,
DOI : 10.1109/ISVLSI.2013.6654616
