Some analytical solutions for validation of free surface flow computational codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fluid Mechanics Année : 2021
We present several time dependent analytical solutions for the incompressible Euler system with free surface. These analytical solutions give quantitative descriptions of some physical phenomena, such as water motion or waves on space variable topography, and can be used as reference solutions when validating numerical simulation codes. They concern fluid flows governed by Euler equations with or without hydrostatic hypothesis including wet/dry interface, variable density and wide variety of boundary conditions.
Various_Analytical_Solutions.pdf (2.95 Mo) Télécharger le fichier
hal-01831622 , version 1 (06-07-2018)
hal-01831622 , version 2 (24-01-2020)
hal-01831622 , version 3 (17-12-2020)
Marie-Odile Bristeau, Bernard Di Martino, Anne Mangeney, Jacques Sainte-Marie, Fabien Souillé. Some analytical solutions for validation of free surface flow computational codes. Journal of Fluid Mechanics, 2021, Journal of Fluid Mechanics, 913 (A17), ⟨10.1017/jfm.2020.1179⟩. ⟨hal-01831622v3⟩
684 Consultations
437 Téléchargements
