Self-Organizing Flying Drones with Massive MIMO Networking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This article studies distributed algorithms to control self-organizing swarm drone hotspots with massive MIMO networking capabilities - a network scenario referred to as OrgSwarm. We attempt to answer the following fundamental question: what is the optimal way to provide spectrally-efficient wireless access to a multitude of ground nodes with mobile base stations/aerial relays mounted on a swarm of drones and endowed with a large number of antennas; when we can control the position of many-antenna-enabled drones, access association of ground nodes to drones, and the transmit power of ground nodes? The article first derives a mathematical formulation of the problem of spectral efficiency maximization through joint control of the movement of many-antenna-enabled aerial drones, access association of single-antenna ground nodes to many-antenna drones, and transmit power of ground nodes. It is shown that the resulting network control problem is a mixed integer nonlinear nonconvex programming problem (MINLP). We then first design a distributed solution algorithm with polynomial computational complexity. Then, a centralized but globally optimal solution algorithm is designed based on a combination of the branch and bound framework and convex relaxation techniques to provide a performance benchmark for the distributed algorithm. Results indicate that the distributed algorithm achieves a network spectral efficiency very close (over 95% on average) to the global optimum.
paper03.pdf (187.24 Ko) Télécharger le fichier
hal-01832485 , version 1 (07-07-2018)
Paternité
  • HAL Id : hal-01832485 , version 1
Zhangyu Guan, Nan Cen, Tommaso Melodia, Scott Pudlewski. Self-Organizing Flying Drones with Massive MIMO Networking. 17th Annual Mediterranean Ad Hoc Networking Workshop (Med-Hoc-Net 2018), Jun 2018, Capri Island, Italy. pp.15-22. ⟨hal-01832485⟩
123 Consultations
250 Téléchargements
