, , 2005.
Model reduction of linear switched systems and LPV state-space models, Aalborg University, 2015. ,
Model reduction by nice selections for linear switched systems, IEEE Transactions on Automatic Control, vol.61, issue.11, pp.3422-3437, 2016. ,
DOI : 10.1109/tac.2016.2518023
URL : https://hal.archives-ouvertes.fr/hal-01406906
Model order reduction for linear and nonlinear systems: a system-theoretic perspective, Archives of Computational Methods in Engineering, vol.21, pp.331-358, 2014. ,
DOI : 10.1007/s11831-014-9111-2
Dual pairs of generalized lyapunov inequalities and balanced truncation of stochastic linear systems, IEEE Transactions on Automatic Control, vol.62, issue.2, pp.782-791, 2017. ,
DOI : 10.1109/tac.2016.2572881
URL : http://hdl.handle.net/21.11116/0000-0000-CEBA-7
A survey of projection-based model reduction methods for parametric dynamical systems, SIAM Review, vol.57, issue.4, pp.483-531, 2015. ,
Model Order Reduction for Differential-Algebraic Equations: A Survey, Surveys in Differential-Algebraic Equations IV, Part of the series Differential-Algebraic Equations Forum, pp.107-160, 2017. ,
DOI : 10.1007/978-3-319-46618-7_3
Model reduction for nonlinear control systems with stability preservation and error bounds, 2012. ,
Gramian based approach to model order-reduction for discrete-time switched linear systems, Proceedings of the 18th Mediterranean Conference on Control and Automation, pp.1224-1229, 2010. ,
DOI : 10.1109/med.2010.5547881
Model reduction for discrete-time switched linear time-delay systems via the H? stability, Control and Intelligent Systems, vol.39, issue.1, pp.1-9, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00851904
Model order-reduction for discrete-time switched linear systems, Int. J. Systems Science, vol.43, issue.9, pp.1753-1763, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00851919
A collection of benchmark examples for model reduction of linear time invariant dynamical systems, 2002. ,
Stability analysis and control synthesis for switched systems: a switched Lyapunov function approach, IEEE Transactions on Automatic Control, vol.47, issue.11, pp.1883-1887, 2002. ,
Model simplification for switched hybrid systems, Systems and Control Letters, vol.55, pp.1015-1021, 2006. ,
DOI : 10.1016/j.sysconle.2006.06.014
Approximate simulation relations for hybrid systems, Discrete Event Dynamic Systems, vol.18, issue.2, pp.163-179, 2008. ,
DOI : 10.3182/20060607-3-it-3902.00022
URL : https://hal.archives-ouvertes.fr/hal-00307035
, Hybrid Dynamical Systems: Modeling, Stability, and Robustness, 2012.
Numerical solution of hybrid systems of differential-algebraic equations, Computer Methods in Applied Mechanics and Engineering, vol.197, pp.693-705, 2008. ,
Adaptive Control, part of the series Communications and Control Engineering, Multimodel Adaptive Control with Switching, vol.13, pp.457-475, 2011. ,
Switching in Systems and Control, 2008. ,
Balanced truncation model reduction for large-scale systems in descriptor form, vol.45, pp.83-115, 2005. ,
DOI : 10.1007/3-540-27909-1_3
Hybrid systems of differential-algebraic equations-Analysis and numerical solution, Journal of Process Control, vol.19, pp.1218-1228, 2009. ,
DOI : 10.1016/j.jprocont.2009.05.002
A simultaneous balanced truncation approach to model reduction of switched linear systems, IEEE Transactions on Automatic Control, vol.57, issue.12, pp.3118-3131, 2012. ,
DOI : 10.1109/tac.2012.2202031
URL : https://pure.rug.nl/ws/files/2448349/2012IEEETransAutomControlMonshizadeh.pdf
Principal component analysis in linear systems: controllability, observability, and model reduction, IEEE Trans. Automat. Control, vol.26, pp.17-32, 1981. ,
Adaptive control using multiple models, switching and tuning, International Journal of Adaptive Control and Signal Processing, vol.17, pp.87-102, 2003. ,
Model reduction of switched affine systems, Automatica, vol.70, pp.57-65, 2016. ,
Model reduction via balanced state space representation, IEEE Trans. Automat. Control, vol.27, p.382387, 1982. ,
Realization theory for linear and bilinear switched systems: formal power series approach-Part I: realization theory of linear switched systems. ESAIM Control, Optimization and Caluculus of Variations, vol.17, pp.410-445, 2011. ,
Realization theory for linear hybrid systems, IEEE Transactions on Automatic Control, vol.55, issue.10, pp.2282-2297, 2010. ,
Partial-realization theory for linear switched systems-a formal power series approach, Automatica, vol.47, pp.2177-2184, 2011. ,
Observability of switched linear systems. Hybrid Dynamical System Control and Observation, from Theory to Application, 2013. ,
Balanced truncation for linear switched systems, Nonlinear Analysis: Hybrid Systems, Special Issue related to IFAC Conference on Analysis and Design of Hybrid Systems (ADHS 12), vol.10, pp.4-20, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01832883
1.0.1, The Matrix Equations Sparse Solvers Library, 2016. ,
Model reduction for linear time-varying systems, 2004. ,
Model reduction for hybrid systems with state-dependent jumps, IFAC-PapersOnLine, vol.49, issue.18, pp.850-855, 2016. ,
Generalized gramian framework for model/controller order reduction of switched systems, International Journal of Systems Science, vol.42, issue.8, pp.1277-1291, 2011. ,
Model reduction of switched systems based on switching generalized gramians, International Journal of Innovative Computing, Information and Control, vol.8, issue.7, pp.5025-5044, 2012. ,
Switched linear systems: control and design, 2005. ,
Stability Theory of Switched Dynamical Systems, 2011. ,
Switched differential algebraic equations, chap. 6. Advances in Industrial Control, Dynamics and Control of Switched Electronic Systems, 2012. ,
Input-to-state stability of switched systems and switching adaptive control, Automatica, vol.43, issue.4, pp.639-646, 2007. ,
µ-Dependent model reduction for uncertain discrete-time switched linear systems with average dwell time, International Journal of Control, vol.82, issue.2, pp.378-388, 2009. ,
On H 2 model reduction of bilinear systems, Automatica, vol.38, pp.205-216, 2002. ,
H-infinity model reduction for uncertain switched linear discrete-time systems, Automatica, vol.44, issue.8, pp.2944-2949, 2008. ,
Stability analysis and H? model reduction for switched discrete-time time-delay systems, Mathematical Problems in Engineering, vol.15, 2014. ,
