Improving the "Correct Eventual Consistency" Tool - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
Sreeja S Nair
  • Fonction : Auteur
  • PersonId : 1022830
Marc Shapiro
Preserving invariants while designing distributed applications under weak consistency models is difficult. The CEC (Correct Eventual Consistency Tool) is meant to aid the application designer in this task. It provides information about the errors during concurrent operations and suggestions on how and where to synchronize operations. This report presents two features of the tool: providing a counterexample for debugging and concurrency control suggestions.
RR-9191.pdf (619.87 Ko) Télécharger le fichier
RR-9191.zip (1.13 Mo) Télécharger le fichier
hal-01832888 , version 1 (09-07-2018)
Sreeja S Nair, Marc Shapiro. Improving the "Correct Eventual Consistency" Tool. [Research Report] RR-9191, Sorbonne Université. 2018. ⟨hal-01832888⟩
147 Consultations
81 Téléchargements
