New interface
Journal articles
Fast, generic and reliable control and simulation of soft robots using model order reduction
Olivier Goury 1 Christian Duriez 1
1 DEFROST - Deformable Robots Simulation Team
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : Obtaining an accurate mechanical model of a soft deformable robot compatible with the computation time imposed by robotic applications is often considered as an unattainable goal. This paper should invert this idea. The proposed methodology offers the possibility to dramatically reduce the size and the online computation time of a Finite Element Model (FEM) of a soft robot. After a set of expensive offline simulations based on the whole model, we apply snapshot-proper orthogonal decomposition to sharply reduce the number of state variables of the soft robot model. To keep the computational efficiency, hyperre-duction is used to perform the integration on a reduced domain. The method allows to tune the error during the two main steps of complexity reduction. The method handles external loads (contact, friction, gravity...) with precision as long as they are tested during the offline simulations. The method is validated on two very different examples of FE models of soft robots and on one real soft robot. It enables acceleration factors of more than 100, while saving accuracy, in particular compared to coarsely meshed FE models and provides a generic way to control soft robots.
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01834483
Contributor : Olivier Goury Connect in order to contact the contributor
Submitted on : Tuesday, July 10, 2018 - 3:45:21 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Thursday, October 11, 2018 - 2:21:28 PM
Identifiers
Citation
Olivier Goury, Christian Duriez. Fast, generic and reliable control and simulation of soft robots using model order reduction. IEEE Transactions on Robotics, 2018, 34 (6), pp.1565 - 1576. ⟨10.1109/TRO.2018.2861900⟩. ⟨hal-01834483⟩
Share
Metrics
Record views
1821
Files downloads
878
