Subdivisions of oriented cycles in digraphs with large chromatic number - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Graph Theory Année : 2018
An oriented cycle is an orientation of a undirected cycle. We first show that for any oriented cycle C, there are digraphs containing no subdivision of C (as a subdigraph) and arbitrarily large chromatic number. In contrast, we show that for any C a cycle with two blocks, every strongly connected digraph with sufficiently large chromatic number contains a subdivision of C. We prove a similar result for the antidirected cycle on four vertices (in which two vertices have out-degree 2 and two vertices have in-degree 2).
bounded-chi-cycle.pdf (234.68 Ko) Télécharger le fichier
hal-01834779 , version 1 (10-07-2018)
Nathann Cohen, Frédéric Havet, William Lochet, Nicolas Nisse. Subdivisions of oriented cycles in digraphs with large chromatic number. Journal of Graph Theory, 2018, 89 (4), pp.439-456. ⟨10.1002/jgt.22360⟩. ⟨hal-01834779⟩
383 Consultations
532 Téléchargements
