, Microphone Arrays: Signal Processing Techniques and Applications, 2001.
Distant Speech Recognition, 2009. ,
Techniques for Noise Robustness in Automatic Speech Recognition, 2012. ,
Audio Source Separation and Speech Enhancement, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01881431
Multichannel speech separation with recurrent neural networks from high-order Ambisonics recordings, Proc. of ICASSP, pp.36-40, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01699759
Periphony: with-height sound reproduction, JAES, vol.21, issue.1, pp.2-10, 1973. ,
MPEG-H 3D audioThe new standard for coding of immersive spatial audio, IEEE J. Sel. Topics Signal Process, vol.9, issue.5, pp.770-779, 2015. ,
Spatial sound reproduction with directional audio coding, JAES, vol.55, issue.6, pp.503-516, 2007. ,
3D source localization in the spherical harmonic domain using a pseudointensity vector, Proc. of EUSIPCO, pp.442-446, 2010. ,
Multiple source localisation in the spherical harmonic domain, Proc. of IWAENC, pp.258-262, 2014. ,
Classical and modern direction-ofarrival estimation, 2009. ,
Robust localization in reverberant rooms, Microphone Arrays: Signal Processing Techniques and Applications, 2001. ,
Multi-source TDOA estimation in reverberant audio using angular spectra and clustering, Signal Processing, vol.92, issue.8, pp.1950-1960, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00576297
Multichannel source activity detection, localization, and tracking, Audio Source Separation and Speech Enhancement, 2018. ,
The generalized correlation method for estimation of time delay, IEEE Trans. Acoustics, Speech, Signal Process, vol.24, issue.4, pp.320-327, 1976. ,
A robust method for speech signal time-delay estimation in reverberant rooms, Proc. of ICASSP, vol.1, pp.375-378, 1997. ,
Multiple emitter location and signal parameter estimation, IEEE Trans. Antennas Propag, vol.34, issue.3, pp.276-280, 1986. ,
ESPRIT-estimation of signal parameters via rotational invariance techniques, IEEE Trans. Acoustics, Speech, Signal Process, vol.37, issue.7, pp.984-995, 1989. ,
Localization of multiple speakers under high reverberation using a spherical microphone array and the direct-path dominance test, IEEE/ACM Trans. Audio, Speech and Lang. Proc, vol.22, issue.10, pp.1494-1505, 2014. ,
Robust localization of multiple sources in reverberant environments using EB-ESPRIT with spherical microphone arrays, Proc. of ICASSP, pp.117-120, 2011. ,
Spatial impulse response rendering I: Analysis and synthesis, JAES, vol.53, issue.12, pp.1115-1127, 2005. ,
Direction estimation based on sound intensity vectors, Proc. EUSIPCO, pp.700-704, 2009. ,
Augmented intensity vectors for direction of arrival estimation in the spherical harmonic domain, IEEE/ACM Trans. Audio, Speech and Lang. Proc, vol.25, issue.10, 1956. ,
Exploiting deep neural networks and head movements for binaural localisation of multiple speakers in reverberant conditions, Proc. of Interspeech, pp.3302-3306, 2015. ,
A learning-based approach to direction of arrival estimation in noisy and reverberant environments, Proc. of ICASSP, pp.2814-2818, 2015. ,
Sound source localization based on deep neural networks with directional activate function exploiting phase information, Proc. of ICASSP, pp.405-409, 2016. ,
Broadband DOA estimation using convolutional neural networks trained with noise signals, Proc. of WASPAA, pp.136-140, 2017. ,
, Multi-speaker localization using convolutional neural network trained with noise, ML4Audio Worskhop at NIPS, 2017.
Direction of arrival estimation for multiple sound sources using convolutional recurrent neural network, Proc. EUSIPCO, 2018. ,
Exploiting CNNs for improving acoustic source localization in noisy and reverberant conditions, IEEE Trans. Em. Topics Comput. Intell, vol.2, issue.2, pp.103-116, 2018. ,
Joint localization and classification of multiple sound sources using a multi-task neural network, Proc. Interspeech, pp.312-316, 2018. ,
On pixel-wise explanations for non-linear classifier decisions by layer-wise relevance propagation, PLOS ONE, vol.10, issue.7, p.130140, 2015. ,
Spatial audio feature discovery with convolutional neural networks, Proc. of ICASSP, pp.6797-6801, 2018. ,
DOI : 10.1109/icassp.2018.8462315
URL : https://research.aalto.fi/files/28749078/ELEC_et_al_Spatial_audio_feature_discovery_with_convolutional_neural_networks_ICASSP_2018.pdf
Analyzing classifiers: Fisher vectors and deep neural networks, Proc. CVPR, pp.2912-2920, 2016. ,
DOI : 10.1109/cvpr.2016.318
URL : http://arxiv.org/pdf/1512.00172
CRNN-based joint azimuth and elevation localization with the Ambisonics intensity vector, Proc. of IWAENC, pp.241-245, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01840453
Représentation de champs acoustiques, application à la transmission et à la reproduction de scènes sonores complexes dans un contexte multimédia, 2000. ,
Parametric time-frequency domain spatial audio, 2017. ,
A note on instantaneous and time-averaged active and reactive sound intensity, J. of Sound and Vibration, vol.147, issue.3, pp.489-496, 1991. ,
Analyse de scène sonore multi-capteurs, 2017. ,
Batch normalization: accelerating deep network training by reducing internal covariate shift, Proc. of ICML, pp.448-456, 2015. ,
Methods for interpreting and understanding deep neural networks, Digital Signal Processing, vol.73, pp.1-15, 2018. ,
Sensitivity analysis for minimization of input data dimension for feedforward neural network, Proc. of ISCAS, vol.6, pp.447-450, 1994. ,
Explaining recurrent neural network predictions in sentiment analysis, Proc. of WASSA, pp.159-168, 2017. ,
DOI : 10.18653/v1/w17-5221
URL : https://doi.org/10.18653/v1/w17-5221
TRAMP: Tracking by a Real-time AMbisonicbased Particle filter, LOCATA workshop at IWAENC, 2018. ,
Sound localization in reverberant environment based on the model of the precedence effect, IEEE Trans. Instrum. Meas, vol.46, issue.4, pp.842-846, 1997. ,
Source localization in complex listening situations: selection of binaural cues based on interaural coherence, JASA, vol.116, issue.5, pp.3075-3089, 2004. ,
The precedence effect, JASA, vol.106, issue.4, pp.1633-1654, 1999. ,
Image method for efficiently simulating small-room acoustics, JASA, vol.65, issue.4, pp.943-950, 1979. ,
Room impulse response generator, 2006. ,
EM32 Eigenmike microphone array release notes (v17. 0), Tech. Rep, 2013. ,
BREF, a large vocabulary spoken corpus for French, Proc. of Eurospeech, pp.505-508, 1991. ,
Incorporating Nesterov momentum into Adam, Univ. of Stanford, Tech. Rep, 2015. ,
The LOCATA challenge data corpus for acoustic source localization and tracking, Proc. of SAM, pp.410-414, 2018. ,
The Hungarian method for the assignment problem, Naval Research Logistics Quarterly, vol.2, issue.1-2, pp.83-97, 1955. ,
The 2008 signal separation evaluation campaign: a community-based approach to large-scale evaluation, Proc. of ICA, pp.734-741, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00544168
