Delikaris-Manias, and A. Politis, Parametric Time-Frequency Domain Spatial Audio, 2017. ,
Audio Source Separation and Speech Enhancement, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01120685
The generalized correlation method for estimation of time delay, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.24, issue.4, pp.320-327, 1976. ,
DOI : 10.1109/TASSP.1976.1162830
A robust method for speech signal time-delay estimation in reverberant rooms, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.375-378, 1997. ,
DOI : 10.1109/ICASSP.1997.599651
URL : http://cvrr.ucsd.edu/ece285/papers/tdoa_brandstein.pdf
Multiple emitter location and signal parameter estimation, IEEE Transactions on Antennas and Propagation, vol.34, issue.3, pp.276-280, 1986. ,
DOI : 10.1109/TAP.1986.1143830
Periphony : with-height sound reproduction, J. Audio Eng. Soc, vol.21, issue.1, pp.2-10, 1973. ,
MPEG-H 3D Audio???The New Standard for Coding of Immersive Spatial Audio, IEEE Journal of Selected Topics in Signal Processing, vol.9, issue.5, pp.770-779, 2015. ,
DOI : 10.1109/JSTSP.2015.2411578
URL : http://doi.org/10.1109/jstsp.2015.2411578
Spatial sound reproduction with directional audio coding, J. Audio Eng. Soc, vol.55, issue.6, pp.503-516, 2007. ,
3D source localization in the spherical harmonic domain using a pseudointensity vector, Proc. of EUSIPCO, pp.442-446, 2010. ,
Threedimensional sound source localization using B-format signals, Int. J. of Advances in Telecommunications Electrotechnics, Signals and Systems, vol.2, issue.2, 2013. ,
DOI : 10.11601/ijates.v2i2.35
URL : http://www.ijates.org/index.php/ijates/article/download/35/50
Improved localization of sound sources using multi-band processing of ambisonic components, Proc. of AES Conv, pp.1-11, 2009. ,
Localization of Multiple Speakers under High Reverberation using a Spherical Microphone Array and the Direct-Path Dominance Test, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.10, pp.1494-1505, 2014. ,
DOI : 10.1109/TASLP.2014.2337846
Analyse de scène sonore multi-capteurs, 2017. ,
Exploiting deep neural networks and head movements for binaural localisation of multiple speakers in reverberant conditions, Proc. of Interspeech, pp.3302-3306, 2015. ,
DOI : 10.1109/taslp.2017.2750760
URL : http://orbit.dtu.dk/files/139685925/taslp_ma_2750760_proof_color.pdf
A learning-based approach to direction of arrival estimation in noisy and reverberant environments, 2015 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2814-2818, 2015. ,
DOI : 10.1109/ICASSP.2015.7178484
Sound source localization based on deep neural networks with directional activate function exploiting phase information, 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.405-409, 2016. ,
DOI : 10.1109/ICASSP.2016.7471706
DNN based robust DOA estimation in reverberant, noisy and multisource environment, 2018. ,
Broadband doa estimation using convolutional neural networks trained with noise signals, 2017 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.136-140, 2017. ,
DOI : 10.1109/WASPAA.2017.8170010
URL : http://arxiv.org/pdf/1705.00919
Direction of arrival estimation for multiple sound sources using convolutional recurrent neural network, 2017. ,
A note on instantaneous and time-averaged active and reactive sound intensity, Journal of Sound and Vibration, vol.147, issue.3, pp.489-496, 1991. ,
DOI : 10.1016/0022-460X(91)90496-7
Incorporating Nesterov momentum into Adam, Tech. Rep, 2015. ,
Deep neural networks for multiple speaker detection and localization, Proc. of ICRA, 2018. ,
Image method for efficiently simulating small???room acoustics, The Journal of the Acoustical Society of America, vol.65, issue.4, pp.943-950, 1979. ,
DOI : 10.1121/1.382599
Room impulse response generator, Tech. Rep, 2006. ,
BREF, a large vocabulary spoken corpus for French, Proc. of Eurospeech, pp.505-508, 1991. ,
The 2008 Signal Separation Evaluation Campaign: A Community-Based Approach to Large-Scale Evaluation, Proc. of ICA, pp.734-741, 2009. ,
DOI : 10.1109/ICASSP.2009.4959531
URL : https://hal.archives-ouvertes.fr/inria-00544168
A novel entropy estimator and its application to ICA, 2009 IEEE International Workshop on Machine Learning for Signal Processing, pp.1-6, 2009. ,
DOI : 10.1109/MLSP.2009.5306208
