Open Loop Execution of Tree-Search Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In the context of tree-search stochastic planning algorithms where a generative model is available, we consider on-line planning algorithms building trees in order to recommend an action. We investigate the question of avoiding re-planning in subsequent decision steps by directly using the sub-tree as an action recommender. Firstly, we propose a method for open loop control via a new algorithm taking the decision of re-planning or not at each time step based on an analysis of the statistics of the sub-tree. Secondly , we show that the probability of selecting a subopti-mal action at any depth of the tree can be upper bounded and converges towards zero. Moreover, this upper bound decays in a logarithmic way between subsequent depths. This leads to a distinction between node-wise optimality and state-wise optimality. Finally, we empirically demonstrate that our method achieves a compromise between loss of performance and computational gain.
JFPDA_2018_paper_2.pdf (332.87 Ko) Télécharger le fichier
hal-01840583 , version 1 (16-07-2018)
  • HAL Id : hal-01840583 , version 1
Erwan Lecarpentier, Guillaume Infantes, Charles Lesire, Emmanuel Rachelson. Open Loop Execution of Tree-Search Algorithms. Journées Francophones sur la Planification, la Décision et l'Apprentissage pour la conduite de systèmes 2018 (JFPDA 2018), Jul 2018, Nancy, France. ⟨hal-01840583⟩
120 Consultations
69 Téléchargements
