Survey of Texture Mapping, IEEE Computer Graphics and Applications, vol.6, issue.11, pp.56-57, 1986. ,
DOI : 10.1109/MCG.1986.276672
A survey of models, analysis tools and compensation methods for the control of machines with friction, Automatica, vol.30, issue.7, pp.1083-1138, 1994. ,
DOI : 10.1016/0005-1098(94)90209-7
A tactile shape sensing and display system for teleoperated manipulation, Proceedings of 1995 IEEE International Conference on Robotics and Automation, pp.641-646, 1995. ,
DOI : 10.1109/ROBOT.1995.525356
Human shape recognition performance for 3D tactile display, IEEE Transactions on Systems, Man, and Cybernetics - Part A: Systems and Humans, vol.29, issue.6, pp.637-64, 1999. ,
DOI : 10.1109/3468.798067
Evidence for the duplex theory of tactile texture perception. Attention, Perception, and Psychophysics 62, pp.695-705, 2000. ,
Haptic discrimination of softness in teleoperation: the role of the contact area spread rate, IEEE Transactions on Robotics and Automation, vol.16, issue.5, pp.496-504, 2000. ,
DOI : 10.1109/70.880800
Rate-hardness: a new performance metric for haptic interfaces, IEEE Transactions on Robotics and Automation, vol.16, issue.4, pp.357-371, 2000. ,
DOI : 10.1109/70.864228
Reality-based models for vibration feedback in virtual environments, IEEE/ASME Transactions on Mechatronics, vol.6, issue.3, pp.245-252, 2001. ,
DOI : 10.1109/3516.951362
Material discrimination and thermal perception, 11th Symposium on Haptic Interfaces for Virtual Environment and Teleoperator Systems, 2003. HAPTICS 2003. Proceedings., pp.171-178, 2003. ,
DOI : 10.1109/HAPTIC.2003.1191267
Toward event-based haptics: rendering contact using open-loop force pulses, 12th International Symposium on Haptic Interfaces for Virtual Environment and Teleoperator Systems, 2004. HAPTICS '04. Proceedings., p.24, 2004. ,
DOI : 10.1109/HAPTIC.2004.1287174
Display of haptic shape at different scales, Proceedings of Eurohaptics, pp.20-27, 2004. ,
Display of Holistic Haptic Sensations by Combined Tactile and Kinesthetic Feedback, Presence: Teleoperators and Virtual Environments, vol.6, issue.3, pp.1-15, 2004. ,
DOI : 10.1109/86.712218
A haptic-rendering technique based on hybrid surface representation, IEEE computer graphics and applications, vol.24, issue.2, pp.66-75, 2004. ,
Trajectory of contact region on the fingerpad gives the illusion of haptic shape, Experimental Brain Research, vol.63, issue.8, pp.387-394, 2005. ,
DOI : 10.3758/BF03194545
Novel haptic mouse system for holistic haptic display and potential of vibrotactile stimulation, IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.1980-1985, 2005. ,
Fixed-step friction simulation: from classical Coulomb model to modern continuous models, 2005 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.1009-1016, 2005. ,
DOI : 10.1109/IROS.2005.1545579
Improving contact realism through event-based haptic feedback, IEEE Transactions on Visualization and Computer Graphics, vol.12, issue.2, pp.219-230, 2006. ,
DOI : 10.1109/TVCG.2006.32
Haptic and visual perception of roughness, Acta Psychologica, vol.124, issue.2, pp.177-189, 2007. ,
DOI : 10.1016/j.actpsy.2006.03.002
Alternative display of friction represented by tactile stimulation without tangential force. Haptics: perception , devices and scenarios, pp.619-629, 2008. ,
A texturebased haptic model design with 3D brush, 18th International Conference on Artificial Reality and Telexistence, pp.51-56, 2008. ,
Magnitude estimation of softness, Experimental Brain Research, vol.73, issue.2, pp.133-142, 2008. ,
DOI : 10.3758/BF03194906
URL : https://link.springer.com/content/pdf/10.1007%2Fs00221-008-1507-5.pdf
Design of a Multilevel Haptic Display. The Sense of Touch and its Rendering, pp.207-224, 2008. ,
DOI : 10.1007/978-3-540-79035-8_10
Cues for Haptic Perception of Compliance, IEEE Transactions on Haptics, vol.2, issue.4, pp.189-199, 2009. ,
DOI : 10.1109/TOH.2009.16
A hybrid rugosity mesostructure (HRM) for rendering fine haptic detail, 2009. ,
Local Surface Orientation Dominates Haptic Curvature Discrimination, IEEE Transactions on Haptics, vol.2, issue.2, pp.94-102, 2009. ,
URL : http://www.cim.mcgill.ca/~haptic/pub/MW-ET-AL-TOH-09.pdf
Fingerpad Skin Stretch Increases the Perception of Virtual Friction, IEEE Transactions on Haptics, vol.2, issue.4, pp.212-223, 2009. ,
DOI : 10.1109/TOH.2009.34
Tactile perception of thermal diffusivity. Attention, perception, and psychophysics, pp.481-489, 2009. ,
Tactual perception of material properties, Vision Research, vol.50, issue.24, pp.2775-2782, 2010. ,
DOI : 10.1016/j.visres.2010.10.005
High frequency acceleration feedback significantly increases the realism of haptically rendered textured surfaces, 2010 IEEE Haptics Symposium, pp.141-148, 2010. ,
DOI : 10.1109/HAPTIC.2010.5444665
, TeslaTouch: electrovibration for touch surfaces. UIST, pp.283-292, 2010.
Haptic annotation for an interactive image, Proceedings of the 5th International Confernece on Ubiquitous Information Management and Communication, ICUIMC '11, p.51, 2011. ,
DOI : 10.1145/1968613.1968675
ActivePaD surface haptic device, 2012 IEEE Haptics Symposium (HAPTICS), pp.407-414, 2012. ,
DOI : 10.1109/HAPTIC.2012.6183823
Refined methods for creating realistic haptic virtual textures from tool-mediated contact acceleration data, 2012 IEEE Haptics Symposium (HAPTICS), pp.385-391, 2012. ,
DOI : 10.1109/HAPTIC.2012.6183819
, Haptic editor. SIG- GRAPH Asia Emerging Technologies, p.14, 2012.
Psychophysical Dimensions of Tactile Perception of Textures, IEEE Transactions on Haptics, vol.6, issue.1, pp.81-93, 2012. ,
DOI : 10.1109/TOH.2012.32
A Change in the Fingertip Contact Area Induces an Illusory Displacement of the Finger, Eurohaptics, pp.72-79, 2014. ,
DOI : 10.1007/978-3-662-44196-1_10
The effect of damping on the perception of hardness, World Haptics Conference, pp.82-87, 2015. ,
Effects of Mechanical Parameters on Hardness Experienced by Damped Natural Vibration Stimulation, 2015 IEEE International Conference on Systems, Man, and Cybernetics, pp.1539-1544, 2015. ,
DOI : 10.1109/SMC.2015.272
NormalTouch and TextureTouch, Proceedings of the 29th Annual Symposium on User Interface Software and Technology , UIST '16, pp.717-728, 2016. ,
DOI : 10.1109/WHC.2015.7177714
Hardness perception by tapping: Effect of dynamic stiffness of objects, 2017 IEEE World Haptics Conference (WHC), pp.37-41, 2017. ,
DOI : 10.1109/WHC.2017.7989853
, Mura Vision https
