Geometric medians in reconciliation spaces
In evolutionary biology, it is common to study how various entities evolve together, for example, how parasites coevolve with their host, or genes with their species. Coevolution is commonly modelled by considering certain maps or reconciliations from one evolutionary tree P to another H, all of which induce the same map between the leaf-sets of P and H (corresponding to present-day associations). Recently, there has been much interest in studying spaces of reconciliations, which arise by defining some metric d on the set R(P, H,) of all possible reconciliations between P and H. In this paper, we study the following question: How do we compute a geometric median for a given subset of R(P, H,) relative to d, i.e. an element med 2 R(P, H,) such that X 0 2 d(med , 0) X 0 2 d(, 0) holds for all 2 R(P, H,)? For a model where so-called host-switches or transfers are not allowed, and for a commonly used metric d called the edit-distance, we show that although the cardinality of R(P, H,) can be super-exponential, it is still possible to compute a geometric median for a set in R(P, H,) in polynomial time. We expect that this result could be useful for computing a summary or consensus for a set of reconciliations (e.g. for a set of suboptimal reconciliations).
