Revisiting Oxford and Paris: Large-Scale Image Retrieval Benchmarking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper we address issues with image retrieval benchmarking on standard and popular Oxford 5k and Paris 6k datasets. In particular, annotation errors, the size of the dataset, and the level of challenge are addressed: new annotation for both datasets is created with an extra attention to the reliability of the ground truth. Three new protocols of varying difficulty are introduced. The protocols allow fair comparison between different methods, including those using a dataset preprocessing stage. For each dataset, 15 new challenging queries are introduced. Finally, a new set of 1M hard, semi-automatically cleaned distractors is selected. An extensive comparison of the state-of-the-art methods is performed on the new benchmark. Different types of methods are evaluated, ranging from local-feature-based to modern CNN based methods. The best results are achieved by taking the best of the two worlds. Most importantly, image retrieval appears far from being solved.
C107.cvpr18.oxford.pdf (3.17 Mo) Télécharger le fichier
hal-01843075 , version 1 (18-07-2018)
Filip Radenović, Ahmet Iscen, Giorgos Tolias, Yannis Avrithis, Ondřej Chum. Revisiting Oxford and Paris: Large-Scale Image Retrieval Benchmarking. CVPR 2018 - IEEE Computer Vision and Pattern Recognition Conference, Jun 2018, Salt Lake City, United States. pp.1-10. ⟨hal-01843075⟩
217 Consultations
453 Téléchargements
