Evaluation of Interactive Machine Learning Systems - Archive ouverte HAL Access content directly
Book Sections Year : 2018
(1) , (2, 3) , (1)
1
2
3
The evaluation of interactive machine learning systems remains a difficult task. These systems learn from and adapt to the human, but at the same time, the human receives feedback and adapts to the system. Getting a clear understanding of these subtle mechanisms of cooperation and co-adaptation is challenging. In this chapter, we report on our experience in designing and evaluating various interactive machine learning applications from different domains. We argue for coupling two types of validation: algorithm-centered analysis, to study the computational behaviour of the system; and human-centered evaluation, to observe the utility and effectiveness of the application for end-users. We use a visual analytics application for guided search, built using an interactive evolutionary approach, as an exemplar of our work. We argue that human-centered design and evaluation complement al-gorithmic analysis, and can play an important role in addressing the " black-box " effect of machine learning. Finally, we discuss research opportunities that require human-computer interaction methodologies, in order to support both the visible and hidden roles that humans play in interactive machine learning.
evaluation-interactive-machine.pdf (645.63 Ko) Télécharger le fichier
Dates and versions
hal-01845018 , version 1 (20-07-2018)
Identifiers
  • HAL Id : hal-01845018 , version 1
Cite
Nadia Boukhelifa, Anastasia Bezerianos, Evelyne Lutton. Evaluation of Interactive Machine Learning Systems. J. Zhou; F. Chen. Human and Machine Learning Visible, Explainable, Trustworthy and Transparent, Springer, pp.341-360, 2018, 978-3-319-90403-0. ⟨hal-01845018⟩
601 View
146 Download
Share
