Modeling Strategies for Storing Data in Distributed Heterogeneous NoSQL Databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this work, we propose HerM (Heterogeneous Distributed Model), a NoSQL data modeling approach which supports the use of multiple heterogeneous NoSQL systems in a distributed environment. We define the conceptual elements necessary for data modeling, and we identify optimized data distribution patterns. We implemented a flexible framework, where we deployed our proposed modeling strategies and that we evaluated comparing our approach against native the NoSQL data distribution methodology provided by the NoSQL databases MongoDB.
er-2018.pdf (266.28 Ko) Télécharger le fichier
hal-01845031 , version 1 (20-07-2018)
  • HAL Id : hal-01845031 , version 1
Moditha Hewasinghage, Nacéra Bennacer Seghouani, Francesca Bugiotti. Modeling Strategies for Storing Data in Distributed Heterogeneous NoSQL Databases. The International Conference on Conceptual Modeling (ER) , Oct 2018, Xi’an, China. ⟨hal-01845031⟩
159 Consultations
462 Téléchargements
