An application-based characterization of dynamical distance geometry problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimization Letters Année : 2020
The dynamical Distance Geometry Problem (dynDGP) is the problem of finding a realization in a Euclidean space of a weighted undirected graph G representing an animation by relative distances, so that the distances between realized vertices are as close as possible to the edge weights. In the dynDGP, the vertex set of the graph G is the set product of V , representing certain objects, and T , representing time as a sequence of discrete steps. We suppose moreover that distance information is given together with the priority of every distance value. The dynDGP is a special class of the DGP where the dynamics of the problem comes to play an important role. In this work, we propose an application-based characterization of dynDGP instances, where the main criteria are the presence or absence of a skeletal structure, and the rigidity of such a skeletal structure. Examples of considered applications include: multi-robot coordination, crowd simulations, and human motion retargeting.
dynDGP-applications (1).pdf (435.94 Ko) Télécharger le fichier
hal-01846265 , version 1 (25-09-2018)
Antonio Mucherino, Jérémy Omer, Ludovic Hoyet, Paolo Robuffo Giordano, Franck Multon. An application-based characterization of dynamical distance geometry problems. Optimization Letters, 2020, 14 (2), pp.493-507. ⟨10.1007/s11590-018-1302-6⟩. ⟨hal-01846265⟩
470 Consultations
219 Téléchargements
