Stability Analysis of a Nonlinear System with Infinite Distributed Delays Describing Cell Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We want to reconcile some earlier mod-eling ways of the cell cycle in one common framework. Accordingly, we consider a model that contains a compartment where cells may be quiescent for an unlimited time, along with a proliferating phase in which most of the cells may divide, or die, while few of them may be arrested during their cycle for unlimited time. In fact, the cell-cycle arrest may occur for many reasons (DNA damages detected at some checkpoints, insufficient resources for cell grow, drug infusions). We actually extend some early models involving finite distributed delays (taken from [2], [1]) to the case of infinite distributed delays and time-varying parameters. Our main result relies on the construction of a novel Lyapunov-Krasovskii functional, suitable for the analysis of the origin of the system involving infinite distributed delays and time-varying parameters.
ACC2018Paper2_RevisedV2.pdf (793.95 Ko) Télécharger le fichier
hal-01849010 , version 1 (25-07-2018)
Walid Djema, Frédéric Mazenc, Catherine Bonnet, Jean Clairambault, Emilia Fridman. Stability Analysis of a Nonlinear System with Infinite Distributed Delays Describing Cell Dynamics. ACC 2018 - American Control Conference, Jun 2018, Milwaukee, United States. ⟨10.23919/acc.2018.8430869⟩. ⟨hal-01849010⟩
753 Consultations
190 Téléchargements
