Networked Control Systems With Communication Constraints: Tradeoffs Between Transmission Intervals, Delays and Performance, IEEE Transactions on Automatic Control, vol.55, issue.8, pp.1781-1796, 2010. ,
DOI : 10.1109/TAC.2010.2042352
Absolutely Exponential Stability and Temperature Control for Gas Chromatograph System Under Dwell Time Switching Techniques, IEEE Transactions on Cybernetics, vol.46, issue.6, pp.1301-1310, 2016. ,
DOI : 10.1109/TCYB.2015.2450752
Leader-following consensus of a class of stochastic delayed multi-agent systems with partial mixed impulses, Automatica, vol.53, pp.346-354, 2015. ,
DOI : 10.1016/j.automatica.2015.01.008
Stability Analysis of Stochastic Delayed Systems With an Application to Multi-Agent Systems, IEEE Transactions on Automatic Control, vol.61, issue.12, pp.4143-4149, 2016. ,
DOI : 10.1109/TAC.2016.2548559
Reduction Model Approach for Linear Systems With Sampled Delayed Inputs, IEEE Transactions on Automatic Control, vol.58, issue.5, pp.1263-1268, 2013. ,
DOI : 10.1109/TAC.2013.2254193
URL : https://hal.archives-ouvertes.fr/hal-00761296
Estimation of Delay Times in Biological Systems, Annals of Biomedical Engineering, vol.31, issue.11, pp.1423-1439, 2003. ,
DOI : 10.1114/1.1617984
Stabilizing network control for pneumatic systems with time-delays, Mechatronics, vol.19, issue.3, pp.399-409, 2009. ,
DOI : 10.1016/j.mechatronics.2008.09.008
Stability of time-delay systems, 2003. ,
DOI : 10.1007/978-1-4612-0039-0
URL : https://hal.archives-ouvertes.fr/hal-00664367
A delay-dependent stability criterion for systems with uncertain time-invariant delays, IEEE Transactions on Automatic Control, vol.44, issue.4, pp.876-877, 1999. ,
DOI : 10.1109/9.754838
Improved delay-dependent stability criteria for time-delay systems, IEEE Transactions on Automatic Control, vol.50, issue.3, pp.384-387, 2005. ,
Delay-Independent Stability Conditions for Some Classes of Nonlinear Systems, IEEE Transactions on Automatic Control, vol.59, issue.8, pp.2209-2214, 2014. ,
DOI : 10.1109/TAC.2014.2299012
Mixed output-feedback control of second-order neutral systems with time-varying state and input delays, ISA Transactions, vol.47, issue.3, pp.311-324, 2008. ,
DOI : 10.1016/j.isatra.2008.04.002
control of parameter-dependent state-delayed systems using polynomial parameter-dependent quadratic functions, International Journal of Control, vol.10, issue.4, pp.254-263, 2005. ,
DOI : 10.1016/0167-6911(88)90034-5
Stability analysis and <mml:math altimg="si14.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msub><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mi>???</mml:mi></mml:mrow></mml:msub></mml:math> controller synthesis of discrete-time switched systems with time delay, Systems & Control Letters, vol.66, pp.85-93, 2014. ,
DOI : 10.1016/j.sysconle.2013.12.010
Local Capacity $H_{\infty}$ Control for Production Networks of Autonomous Work Systems With Time-Varying Delays, IEEE Transactions on Automation Science and Engineering, vol.7, issue.4, pp.849-857, 2010. ,
DOI : 10.1109/TASE.2010.2046735
Synthesis of Razumikhin and Lyapunov???Krasovskii approaches to stability analysis of time-delay systems, Automatica, vol.51, pp.372-377, 2015. ,
DOI : 10.1016/j.automatica.2014.10.074
New results on H??? dynamic output feedback control for Markovian jump systems with time-varying delay and defective mode information, Optimal Control Applications and Methods, vol.20, issue.3, pp.656-675, 2014. ,
DOI : 10.1002/rnc.1439
A Novel Memory Filtering Design for Semi-Markovian Jump Time-Delay Systems, IEEE Transactions on Systems, Man, and Cybernetics: Systems, vol.47, issue.8, pp.2034-2047, 2017. ,
DOI : 10.1109/TSMC.2017.2759900
Adaptive Fuzzy Hierarchical Sliding-Mode Control for a Class of MIMO Nonlinear Time-Delay Systems With Input Saturation, IEEE Transactions on Fuzzy Systems, vol.25, issue.5, pp.1062-1077, 2017. ,
DOI : 10.1109/TFUZZ.2016.2594273
Approximation-Based Adaptive Fuzzy Tracking Control for a Class of Nonstrict-Feedback Stochastic Nonlinear Time-Delay Systems, IEEE Transactions on Fuzzy Systems, vol.23, issue.5, pp.1746-1760, 2015. ,
DOI : 10.1109/TFUZZ.2014.2375917
Observer-Based Fuzzy Adaptive Output-Feedback Control of Stochastic Nonlinear Multiple Time-Delay Systems, IEEE Transactions on Cybernetics, vol.47, issue.9, 2017. ,
DOI : 10.1109/TCYB.2017.2655501
Stability analysis and control synthesis of neutral systems with time-varying delays and nonlinear uncertainties, Chaos, Solitons & Fractals, vol.42, issue.1, pp.595-603, 2009. ,
DOI : 10.1016/j.chaos.2009.01.028
Stabilization of Networked Control Systems With a New Delay Characterization, IEEE Transactions on Automatic Control, vol.53, issue.9, pp.2142-2148, 2008. ,
DOI : 10.1109/TAC.2008.930190
Tracking Control of Networked Multi-Agent Systems Under New Characterizations of Impulses and Its Applications in Robotic Systems, IEEE Transactions on Industrial Electronics, vol.63, issue.2, pp.1299-1307, 2016. ,
DOI : 10.1109/TIE.2015.2453412
Tracking Control of Robotic Manipulators With Uncertain Kinematics and Dynamics, IEEE Transactions on Industrial Electronics, vol.63, issue.10, pp.6439-6449, 2016. ,
DOI : 10.1109/TIE.2016.2569068
Adaptive Neural Control of Nonlinear Systems With Unknown Control Directions and Input Dead-Zone, IEEE Transactions on Systems, Man, and Cybernetics: Systems, 2017. ,
DOI : 10.1109/TSMC.2017.2709813
Velocity-Free Fault-Tolerant and Uncertainty Attenuation Control for a Class of Nonlinear Systems, IEEE Transactions on Industrial Electronics, vol.63, issue.7, pp.4400-4411, 2016. ,
DOI : 10.1109/TIE.2016.2532284
Diagnosis and fault-tolerant control, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01789124
Attitude Stabilization of Spacecrafts Under Actuator Saturation and Partial Loss of Control Effectiveness, IEEE Transactions on Control Systems Technology, vol.21, issue.6, pp.2251-2263, 2013. ,
DOI : 10.1109/TCST.2012.2236327
Stability of Systems With Controller Failure and Time-Varying Delay, IEEE Transactions on Automatic Control, vol.53, issue.10, pp.2391-2396, 2008. ,
DOI : 10.1109/TAC.2008.2007528
Stability analysis for networked control systems based on average dwell time method, International Journal of Robust and Nonlinear Control, vol.52, issue.1, pp.1774-1784, 2010. ,
DOI : 10.1007/978-1-4612-0017-8
Data-Based Predictive Control for Networked Nonlinear Systems With Network-Induced Delay and Packet Dropout, Proceedings of IEEE 54th Annual Conference on Decision and Control (CDC), pp.1249-1257, 2016. ,
DOI : 10.1109/TIE.2015.2497206
Switching in systems and control, 2003. ,
Stability and Stabilizability of Switched Linear Systems: A Survey of Recent Results, IEEE Transactions on Automatic Control, vol.54, issue.2, pp.308-322, 2009. ,
DOI : 10.1109/TAC.2008.2012009
Dwell-time computation for stability of switched systems with time delays, IET Control Theory & Applications, vol.7, issue.10, pp.1422-1428, 2013. ,
DOI : 10.1049/iet-cta.2011.0749
URL : https://hal.archives-ouvertes.fr/hal-00935511
Delay-dependent stability for discrete systems with large delay sequence based on switching techniques, Automatica, vol.44, issue.11, pp.2902-2908, 2008. ,
DOI : 10.1016/j.automatica.2008.04.006
Stability analysis for systems with large delay period: A switching method, International Journal of Innovative Computing, Information and Control, vol.8, issue.6, pp.4235-4247, 2012. ,
Input-to-State Stability for Nonlinear Systems With Large Delay Periods Based on Switching Techniques, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.61, issue.6, pp.1789-1800, 2014. ,
DOI : 10.1109/TCSI.2013.2295008
On input-to-state stability of systems with time-delay: A matrix inequalities approach, Automatica, vol.44, issue.9, pp.2364-2369, 2008. ,
DOI : 10.1016/j.automatica.2008.01.012
